What size tires
Old Oct 9, 2005 | 09:54 PM
Tsex On 19s's Avatar
Tsex On 19s
Default What size tires
What size tires should I get? The rims sizes are:19X9.5 +25 and 19X8.5 +22, Im not really sure about the ofsets, but there close to those numbers.. please help, and remember I am on a budget.. So looking for a quality tire for a good price..
Old Oct 9, 2005 | 10:01 PM
wayneside's Avatar
wayneside
275/35/18
those are the sizes i have on my volks...i'm using dunlop direzza tires...great tire! good luck and let us know what you choose...
Old Oct 9, 2005 | 10:19 PM
Go here
http://www.tirerack.com/index.jsp
and select the 350Z and wheel options. Then search only 19 inch wheels. Find the appropriate size wheels, and it will tell you the recommended tire sizes. Before you begin shopping for tires, verify the correct tire sizes here
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old Oct 9, 2005 | 10:33 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
245 / 275 /35 19 as stated above...
Old Oct 10, 2005 | 08:48 AM
barthelb's Avatar
barthelb
Master
Im running the same width rims, you can fit a 255FR and 285 Rear and they should not buldge. The rear doesn't rub but my camber is a lil off, I don't know about the front til they wear off. Im sure they fit but not sure about the rubbing if any. But the 285 provides good grip. It was a big difference from a 275 in my case.
Old Oct 10, 2005 | 09:45 AM
SilverII's Avatar
SilverII
I am running T1-R 245/35/19 & 275/35/19 now..... I plan to go to 255/285 for even more meat!!!
Old Oct 10, 2005 | 09:47 AM
Jason@Performance
Performance Nissan
are you going to do 255/35 / 285/35
IMHO I think it is pointless... You get wider tires yes... but then you also get taller tires / (larger diameter) as well... heavier / more rotational mass...
Old Oct 10, 2005 | 01:32 PM
SilverII's Avatar
SilverII
I just dont want the stretched look on the back on 19x9.5 and a little rim protection on the front.
I have a G35C with 19"...so performance is already lost there and it is not everything for me....
kyin
Oct 15, 2015 05:54 AM
