2 Important Questions Before I Order...
Old Dec 26, 2002 | 09:29 AM
Brad4rdHay's Avatar
Brad4rdHay
Default 2 Important Questions Before I Order...
I am VERY close to ordering some I-forged FS-6s in Brushed aluminum finish. But:
1) The only sizes they have are in 8 and 10 inch widths. How would that much stagger (front/rear) affect performance understeer wise? Would I be better off with 8" all around?
2) I know that for an 8.5" front wheel, your suposed to run 245/35 series tires....but could you get away with running 245/40 tires. I like the look of the larger tire and the ride quality would be a tad better. (I know there would be a slight spedo error) But would there be any problems fitment wise, such as rubbing?
Thanks alot in advance.
Old Dec 26, 2002 | 09:52 AM
rodH's Avatar
rodH
a 245 is the largest that is supposed to be run on the 8", so you shouldn't have any problems
Old Dec 26, 2002 | 10:27 AM
Stone Z's Avatar
Stone Z
Thumbs up Re: 2 Important Questions Before I Order...
Damn....those are gonna look HOT!
Post pics *as soon* as they're on!
Old Dec 26, 2002 | 11:32 AM
Brad4rdHay's Avatar
Brad4rdHay
You're damn right they will!
So, whats the verdict. (8"---10") (8"---8") OR!? (10"---10")
Also, my other question is the stock Z has a slightly larger rear overall diameter...is it ok to even them up...ah la, run a slightly larger front tire ratio.
Old Dec 26, 2002 | 11:57 AM
Stone Z's Avatar
Stone Z
Arrow
I would definitely run....
19x8 front/19x10 rear
245/35/19 front
275/35/19 rear
Old Dec 26, 2002 | 01:08 PM
PistolPete's Avatar
PistolPete
I agree with Dlovtsur. 8" in front and 10" in back.
Post pics when you get 'em!
Old Dec 26, 2002 | 09:23 PM
G35 SAGE's Avatar
G35 SAGE
Yup, looks like you're at the very minimum of the 245/35 spectrum with the 8" wheel. So it looks like
19,8 245/35/18
19,10 275/35/18'
That would do it.
The Sage. lol.
G35 SAGE's Avatar
G35 SAGE
I of course based this on the S03 tire specs. Didn't look at anything else.
Old Dec 27, 2002 | 05:40 AM
Traffic's Avatar
Traffic
Default Re: 2 Important Questions Before I Order...
I would go with 8" in front and 10" out back. It shouldn't be too bad. On the street, you'll never know the difference. On the track, I don't it'll be any worse than in stock form. Best of luck and post some pics when they're on--
Old Dec 27, 2002 | 09:00 AM
Brad4rdHay's Avatar
Brad4rdHay
My question is can i run?
Front: 245/40 /19
Rear: 275/35/19
The spedo will be off...I know by a little, but will this configuration fit?
Old Dec 27, 2002 | 10:55 AM
G35 SAGE's Avatar
G35 SAGE
actually your speedo should be fine because you are just looking to increase the o.d. of the front tire. The rear should be in spec. I don't forsee a problem with the proper offset wheel. the Dunlop SP9000 is the cheapest I've found in that size.
nanotech
Oct 2, 2015 05:02 AM
