Work Wheels Thread
Old Jul 21, 2013 | 08:20 AM
  #1101
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
If you're not dropped or lowered, you'll be fine. I have the same size wheels but just slightly different offsets, and I'm lowered on Hotchkis springs. I've never had issues with the fenders.
BTW, nice wheels.
Old Jul 21, 2013 | 08:28 AM
  #1102
323_z33's Avatar
323_z33
No I'm on oem suspension so no rubbing nuthing.??
Old Jul 21, 2013 | 08:54 AM
  #1103
SmoothZ's Avatar
SmoothZ
No rubbing. Not unless you plan on jumping small hills with it like they do in the movies.
Old Jul 21, 2013 | 09:02 AM
  #1104
323_z33's Avatar
323_z33
Lmaooooo phucck dat I Love my sexy car would never do that I'm not that stupid
Old Jul 22, 2013 | 11:48 AM
  #1105
p0tential's Avatar
p0tential
i have 18x10 on all 4 with oem brembos....
<a href="http://www.flickr.com/photos/synth19/6030573473/" title="Brian's Nissan 350z by synth19, on Flickr"><img src="http://farm7.staticflickr.com/6148/6030573473_c30f0e973a.jpg" width="500" height="333" alt="Brian's Nissan 350z"></a>
<a href="http://www.flickr.com/photos/synth19/6030617789/" title="Brian's Nissan 350z by synth19, on Flickr"><img src="http://farm7.staticflickr.com/6080/6030617789_eefdc5f7be.jpg" width="500" height="333" alt="Brian's Nissan 350z"></a>
Old Jul 22, 2013 | 01:46 PM
  #1106
Bmurray350z's Avatar
Bmurray350z
yeah you should get 18x10 on all 4 corners.
Old Jul 22, 2013 | 04:08 PM
  #1107
Waiz's Avatar
Waiz
Nice choice in wheels OP
As Dave said you should be fine as long as you don't go too crazy with tire sizes.
I would go 255-40-18 & 285-40-18 front and rear tire sizes
Since your car is already in the shop getting repainted have the shop roll your rear fenders just in case
Old Jul 22, 2013 | 04:22 PM
  #1108
abarclay's Avatar
abarclay
Good lookin' wheels OP
Old Jul 22, 2013 | 05:47 PM
  #1109
323_z33's Avatar
323_z33
Yea idk about rolling fenders lol it's my dads shop but he's still charging me lol I don't want any vdc/tcs probes so I'm going on 18x10 18x9 I'm getting em by this week from a friend in 9k racing in the city of Covina 1480 flat no tax or bs
Old Jul 22, 2013 | 05:55 PM
  #1110
323_z33's Avatar
323_z33
Default My bby will look
something like this with white xd9s
Old Jul 23, 2013 | 11:51 AM
  #1111
p0tential's Avatar
p0tential
just an fyi: your wheel width is not directly related to any vdc issues. you will only run into problems if you change the diameter ratio between the front and rear tires. again, i have 18x10 on all 4 corners with 255 front and 275 rear.
additionally, even if you believe that the width of the wheel matters, you could still screw up the ratio
a 255/40 is fine for the front, but if you do 285/40 for the rear, you will be 1.1% too slow. whereas, a 275/55 rear will only be .1% too fast. basically, a 285 will read 60 mph when you are actually traveling 60.7 mph. whereas a 275 will read 60.0 mph when you are actually traveling 60 mph.
it doesn't seem like much of a difference but remember the vdc works of the abs sensor so if the rear wheels spin at different speeds than the front then it will trigger the vdc to go off.
much simpler solution is to delete the vdc
or you can do some homework and use this link to figure out proper ratios:
http://www.miata.net/garage/tirecalc.html
Old Jul 23, 2013 | 03:00 PM
  #1112
mr. sparco's Avatar
mr. sparco
Listen to the guy above, 18x10 all around.
Old Jul 23, 2013 | 04:45 PM
  #1113
323_z33's Avatar
323_z33
Hmmm let me think n see I like p0tentials z33 stance ill see wats best thanks a lot guys so if its 18x10 all around it won't **** with vdc if I run tires 255-front... 275-rear it'll be cool??
Old Jul 23, 2013 | 04:47 PM
  #1114
323_z33's Avatar
323_z33
Ok I get u dude did u have to roll fenders or no?
Old Jul 23, 2013 | 07:45 PM
  #1115
p0tential's Avatar
p0tential
yes, fenders were rolled, but i also have spacers on to widen the stance.
please note that i had a typo in my previous response. i meant to say 275/40, not 275/55.
also, i'm not trying to sell you on getting wider wheels or anything. i am just merely educating you that the wheel width is not the determinant of vdc problems. you can choose whatever width wheel you want for the front and back, just make sure that you mate tires to it that don't change the initial ratio and you'll be a-okay.
good luck!
Old Jul 23, 2013 | 10:17 PM
  #1116
323_z33's Avatar
323_z33
Thanx bro I'm going staggered 18x9 18x10
Old Jul 25, 2013 | 09:17 AM
  #1117
AdvanZ33's Avatar
AdvanZ33
Any other R-Disc owners have to use a spacer for Brembo clearance?
Old Jul 26, 2013 | 09:24 AM
  #1118
StuartBinny's Avatar
StuartBinny
XD9
Ford Brake Repair Huntington Beach
Old Jul 26, 2013 | 10:39 AM
  #1119
sofa king's Avatar
sofa king
i need VS-TX in my life.
Old Jul 26, 2013 | 10:41 AM
  #1120
AdvanZ33's Avatar
AdvanZ33
That's what I wanted initially but no high discs were to be found
