Wanting to put 315/30/18's on the rear; what size wheel?
Old Jan 23, 2006 | 03:16 PM
zillinois's Avatar
zillinois
Originally Posted by Sk8fe
What did you ever decide on? I just purchased a used 2003 Track Ed. 350Z that I want to take out on road course tracks for Driver Ed. and seat-time days. Car only has 9800 miles on it!
zillinois, what type of wheel do you run out on the track? What size (widths) front and back and what size and brand tire?
Not meaning to hi-jack this thread so PM me if this is too far off topic. Thanx!
I ran a CCW Classic Street Rim with 9" inch rim in front with a 25 offset and a 10.5" inch rim in back with a 30 offset. Tires were 265/35/18 and 295/35/18. No rubbing with -1.5 camber. This is probably one of the best track setups you can get under the Z without worrying. I ran Toyo T1S and also Pirelli PZero Corsa (R-Compound). PZero are pretty expensive and I'm not sure they even make a 295/35/18 anymore. But the Toyo's should come in those sizes.
Old Jan 23, 2006 | 03:22 PM
zillinois's Avatar
zillinois
Originally Posted by Ep3
From another thread
link to said thread
https://my350z.com/forum/showthread....2&page=2&pp=20
not trying to start no **** i just want to learn before i spend my 1K+ at tirerack..
Here's what can happen to you if you stretch the tire on the rim.. This is from the VRT guys. This is from a post on this board.
"UPDATE ON WHAT HAPPENED OVER THE WEEKEND
Saturday night was its first real test drive. Scott at VRT put 350 miles on it that night! The car did awesome on long trips and had no heat issues or oil leaks. Then Scott took it to some high speeds and noticed that the back end of the car felt a little wierd. Back to VRT he went to check the suspension.
The suspension checked out fine and and then he figured it out. It was the rear tires. Earlier that day they had hand measured the rear tire width. Although the Nitto NT01s were 315s, they actually measured out to be 323s. On the 9.5" rim, the 323s crossed just over the line of stretching the tire on the rim. What was happening was, at high speeds the tire was growing taller, like drag slicks, because they were stretched so much trying to fit the 9.5" rim.
The tires did not rub at all, it was just the stretching problem. So, what we are doing is switching back to the 315/30/18 Michelin Pilot Sport Cups that I was originally going to put on the car. The good news with that is they come in a 285/30/18 which will replace the 275/35/18s I had on the front with the Nitto NT01s. So I lose a tiny bit of width in the rear, but gaining more in the front."
https://my350z.com/forum/showthread....ghlight=double
Old Jan 24, 2006 | 02:32 AM
Sk8fe's Avatar
Sk8fe
Thanx!
JjL
East Canada
Jun 12, 2019 03:04 AM
cashmoney03
Sep 27, 2015 05:24 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
