18x9.0 all the way around?
Old Dec 9, 2005 | 08:50 AM
iamgus_gus's Avatar
iamgus_gus
Default 18x9.0 all the way around?
ok i plan on dropping. and i dont want to rub. also id rather run 18s because i cant live with myself rolling on 19s just too big.
would 18x9.0 all around look ok if i had a decent drop?
also what tire size should i go with since now id be able to potentially swap all 4 tires?
these wheels
Old Dec 9, 2005 | 10:01 AM
jimster716's Avatar
jimster716
265/35/18 if you're going to lower it.
255/40/18 if not.
275/35/18 would work again if you lower it but you're front will rely on offset to avoid rub.
My 18x9.5+22 front and rear rubbed on a 275/40/18 tire at the front requiring me to flare (not roll) the fender.
Old Dec 9, 2005 | 10:15 AM
sharingan625's Avatar
sharingan625
im also thinking about this. tho, im thinking 18x8.5 all around. what is the widest tires i can fit in without looking ridiculous?
Old Dec 9, 2005 | 10:33 AM
iamgus_gus's Avatar
iamgus_gus
do those number fluctuate at all? tires.com(discount) only has 1 kind of tire in 265/35/18
Old Dec 9, 2005 | 11:26 AM
jimster716's Avatar
jimster716
255/40/18 is perfect for an 8.5 or 9" wide wheel. Remember the wider the front tire the greater the effort in turning your steering wheel. The difference between my 275/40/18 front and 245/35/19 front is like night and day.
I also had to turn off my TCS every time i started the car when running the same tires front and rear. Any turn would make the light go on and I'd get the TCS all PO'd.
Old Dec 9, 2005 | 11:30 AM
sharingan625
ouch! didn't think about those problems...
Old Dec 9, 2005 | 12:23 PM
iamgus_gus's Avatar
iamgus_gus
will those problems continue to occur if im running 255/40/18 on both front and back? if so i might as well just get different size wheels and tires and not worry about rotating them since it wouldnt be possible without problems
Old Dec 9, 2005 | 12:45 PM
iamgus_gus's Avatar
iamgus_gus
what about 18x8.0 front and 18x9.0 back will that look wierd on the rim shown above because 18x9 is as wide as it gets for that rim
Old Dec 9, 2005 | 02:27 PM
Thumbs up
+1. The same size wheels all around are fine: the same size tires may cause a headache with TCS. Select a tire for the rear which is a bit taller than the front.
Old Dec 9, 2005 | 02:56 PM
iamgus_gus's Avatar
iamgus_gus
ok so 18x9 in the rear obviously but should i go with same for front or 18x8 since the tires are going to be different? which is better?
Old Dec 9, 2005 | 03:08 PM
Thanks for asking. I don't comment on “looks” so I’ll stick to performance and handing.
Front: 18x8
Rear: 18X9
...works well. No problem with front clearance. And a little extra rubber the rear will help with understeer.
Old Dec 9, 2005 | 03:19 PM
palepony's Avatar
palepony
davidv - "And a little extra rubber the rear will help with understeer"
did you mean width or height of tire?
for width , to lessen understeer you either need to widen the tires up front or more narrow in the rear.
for height, to lessen understeer you either need to shorten your front tires or have taller rear tires
pp
Old Dec 9, 2005 | 03:32 PM
iamgus_gus's Avatar
iamgus_gus
Originally Posted by davidv
Front: 18x8
Rear: 18X9
what about clearance after being lowered?
Old Dec 9, 2005 | 03:33 PM
pp
Excuse my error. A little extra width in the rear will help with OVERSTEER. Sorry.
Old Dec 9, 2005 | 03:39 PM
iamgus_gus's Avatar
iamgus_gus
tokico Dspec struts and i think tien or tein Stech springs not sure on the springs yet. but will it still work?
Old Dec 9, 2005 | 11:40 PM
froggy's Avatar
froggy
No probem, 18/8front with 235/40 & 18/9rear with 255/40. Lowered with Tein S tech + 15mm front spacers/20mm rear spacers for 35 offset all around.
Old Dec 10, 2005 | 09:57 AM
iamgus_gus's Avatar
iamgus_gus
whats this spacer thing? how much are they? and where do i get em?
Old Dec 11, 2005 | 02:23 AM
froggy's Avatar
froggy
Eibach (top notch) http://www.ctd-germany.com/shops/350z/shop_e/index.php
Or somwhere else...
RavSpec
Apr 1, 2011 08:16 PM
