Winter wheels & "Slip" light
Old Dec 15, 2005 | 08:24 PM
bjackson100's Avatar
bjackson100
Default Winter wheels & "Slip" light
Hello,
I have a 2003 350z touring and I just had installed the Blizzak WS-50 17" tires and wheels from thetirerack.com at my local dealer. My problem is - my "slip" light is on at all rpm's over approximately 3000, limiting my acceleration (in all gears). In reading through the posts, I know this can be due to tire size, but I see many of you have this 17" set on your cars.
I did notice, however, that the dealer installed the tires backwards (225/55-17 in the front, 225/50-17 in the rear). Could this make enough of a difference to cause this problem, or is there something else I need to do to solve this problem? Also, will my speedometer be off any noticable amount, and should it be recalibrated? Thanks!
Old Dec 15, 2005 | 08:53 PM
PDX_Racer's Avatar
PDX_Racer
Switch them around immediately, that is what is throwing the "SLIP" light.
Old Dec 16, 2005 | 08:48 AM
djnc's Avatar
djnc
take it back and make them switch the wheels for free...that's definitely the problem
Old Dec 16, 2005 | 12:01 PM
+1. The tires in the rear should be taller than the tires in the front.
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
