18x9.5 Rims, is it possible/recommended to use them as front wheels???
Old Jan 17, 2006 | 02:28 PM
pnutandgiz's Avatar
pnutandgiz
Default 18x9.5 Rims, is it possible/recommended to use them as front wheels???
I have a local guy that is selling Enkei PK6 deep dish wheels for sale. Description from ad:
Brand: Enkei
Model: PK6
Color: Silver w/chrome 3" lip
How many: 4 rims (no tires)
Size: 18X9.5 with a 25mm offset
Bolt pattern: 114.3
I can get the set for like $500 or maybe less. I was just curious to see if they would work. And, if so, will they affect handling, rubbing etc. Also, whatdo you thinks of these rims. I am not totally sold on them but would like some feedback if possible.
Old Jan 17, 2006 | 02:39 PM
Use one of the offset calculators above and compare the new wheels to your current ones. Then check the car with a tape to see if you will have any clearance problems.
Old Jan 17, 2006 | 02:58 PM
SpeedRcr's Avatar
SpeedRcr
there shouldnt be a problem...i have 18x9.0 and 18x10 setup on my car with no problems
SpeedRcr's Avatar
SpeedRcr
Old Jan 17, 2006 | 03:03 PM
mavtais's Avatar
mavtais
Check the new RS Z33 thread... Nissan was able to run the same wheels as the GT-R Nismo wheels. Deep in front and rear. You should be fine.
Old Jan 17, 2006 | 03:05 PM
VO...'s Avatar
VO...
Administrator
You might get better results if you post in the "Modification, brakes/tires/wheels" section
Old Jan 17, 2006 | 03:12 PM
350ztoronto's Avatar
350ztoronto
the pic dun work
Old Jan 17, 2006 | 03:25 PM
Westby's Avatar
Westby
I'm running nismos 18x9.5 all the way around but they're 30+ offset, I've heard that 25 will bug out of the wheel wells. Btw I'm also running a 35 profile so that helps with clearance to the fender.
Old Jan 17, 2006 | 03:39 PM
apharmdb's Avatar
apharmdb
For my street setup I'm running 19X9.5 +22 up front without any problems. Tire size is 255/35/19
Old Jan 17, 2006 | 04:00 PM
350Zteve's Avatar
350Zteve
I run a 18x9.5" wheel up front with a 265/35/18 and it works great. Offset on mine is +27. Your's will stick out 2mm more than mine, but that will be fine.
Old Jan 17, 2006 | 04:08 PM
pedroosan's Avatar
pedroosan
Somebody just posted this link about a good article on which wheels fit and the purpose (it was in the "wider wheels for track" thread 2 days ago or so)
http://www.sportcompactcarweb.com/pr.../0404scc_350z/
EDIT: sorry link was broken
Read it, it says something about having had to use a spacer, offsets, handling and so on...
EDIT Again:
Basically (I am no expert) I think this article means that if you use a 18x9.5 wheel with 25 offset and 275 tires, that it would not work. At least this is my interpretation.
Old Jan 17, 2006 | 06:57 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
that will fit BEAUTIFULLY!
Run fron 275/35/18 and rear 275/40/18 tires...
Old Jan 18, 2006 | 12:04 PM
Westby's Avatar
Westby
well jason you guys are running same thing I am 275's with a 30+ offset on nismos, he wants to use a 25+ offset with 275's won't that bug out?
Old Jan 18, 2006 | 12:06 PM
Jason@Performance
Performance Nissan
nope its only a 5mm difference...
i ran 9.5 +27mm and had room for a 5-10mm spacer
rear 9.5 +30mm can run a 10-15mm spacer... 9.5+25mm is only 5mm more then the 30mm...
Old Jan 18, 2006 | 12:08 PM
z350boy's Avatar
z350boy
Have you taken into consideration the TCS and/or VDC systems??? It seems that if the size if the tires is not staggered as is the stock format it causes the TCS & VDC systems to activate frequently. Check that out to make sure it won't affect you.
Old Jan 18, 2006 | 05:48 PM
pnutandgiz's Avatar
pnutandgiz
Thanks for all the responses guys? I am new to the whole 350z scene and you guys are really helpful.
One more question though, I currently have Infiniti 18 wheels on my Z, the tire sizes are 225/40/18 in the fronts and 245/45/18 in the rear. This may be a dumb question, but will they work with the 18x9.5 wheels if i decided to buy them.
I have attached a pic of the wheels. (hopefully it comes through). Also, do you thin these will look good on a ppw Z
Attached Thumbnails 18x9.5 Rims, is it possible/recommended to use them as front wheels???-enkei-rims.jpg
Old Jan 18, 2006 | 05:56 PM
pnutandgiz's Avatar
pnutandgiz
One more thing, Is it wierd that I have 40s in the front and 45s in the rear??
The tires are brand spankin new and are BFG KDW G-force tires. I bought the car with the Infiniti rims and tires. I really would like to use them if possible.
If i cant, I will just keep these rims ane tires in my garage and switch them as spres as i need them.
Old Jan 18, 2006 | 08:42 PM
Jason@Performance
Performance Nissan
thats one of the reasons i suggest 275/35/18 / 275/40/18 it does not effect the VDC / TCS system and it allows for great turn in and response...
Old Jan 23, 2006 | 03:35 PM
pnutandgiz's Avatar
pnutandgiz
bump
Old Jan 23, 2006 | 04:59 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
So, just to clearify, running an 18x9.5 +25 with 275/35R18 in front works?
Chris
