widened stock g35c wheels to ~10.5inches
Old Mar 1, 2006 | 10:14 AM
  #41
Jun's Avatar
Jun
if i were to widen the 18" OEM performance/touring wheels (6-spoke), then for sure I would need spacers, in order for the wheel to sit flush with the car right?
Otherwise the wheel would be wider, but still sit way inside the fender?
Old Mar 1, 2006 | 10:19 AM
  #42
JimRHIT's Avatar
JimRHIT
Essentially you need spacers to get the original face of the wheel out the "flush" with the fender. Then, you have the original inner clearance PLUS the new spacer's clearance to "grow" inwards with widening. With the right spacer (creating new backspacing), you will be able to widen prolly up to 11" with some magic. 18x10.5 will be big enough to hold any tire you can stick on there though.
Old Mar 1, 2006 | 12:24 PM
  #43
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by Wired 24/7
In my opinion as an engineer, there's 2 things to think about.
1) The welds, if done properly, are going to be stronger than the surrounding metal.
2) The welds are not directly experiencing significant torque from the axle. The only way to break off a weld would be to hold the inside of the rim while twisting the outside. This would never occur in the real world. The outside (street facing) part of the rim transfers momentum and torque to the inside (wheel well facing) part of the rim. That is a VERY LONG weld to break from the kinds of torque that an automobile can deliver.
Conclusion: Safe unless it's a seriously **** job.
Wired, I dont what was your basis for saying things about torque or any other loads for that matter, it almost seems baseless, I may be wrong, can you elaborate a bit more.
I dont know what else was done after welding, was there any kind of heat treatment done to wheels. In engineering business welding is commonly associated with Heat Affected Zone which get prestressed. So heat treatment is generally done to relieve the stresses. Also for a rotating part that is loaded undergoes cyclic loading or fatigue and welding and associated processes if not done properly is fatigue prone. I didnt want to get this technical. But there is no easy way for me to say this.
Any Metallurgy experts on the board will definitely have a lot to add to this, at least thats the process that I have used in the past.
Welding is crudest method to manufacture a rotating part such as wheel and not finish it up with follow on processes. The precision thats needed when a wheel manufacturer uses a roll forming technique cannot be achieved just by welding. Assuming that a welder doesnt use a custom fixture to hold the piece parts together, a one fit to all wheel fixture will not give the same result. The precision tolerances such a radial run out, face run out, eccentricity and axial misalignment need to measured and if are out of design tolerances, need to be machined or discarded, at least thats how it works in the industry.
American SAE J2530 specifications and Japan’s JWL and Germany’s TUV testing standards respectively should be met before any wheel is certified as safe to used on a vehicle. Doing this welding just completely disregarded these specifications.
People give engineering/science/technology far less credit than it deserves and take it for granted. I wish it were easier, but its not.
Old Mar 1, 2006 | 12:59 PM
  #44
jcarp's Avatar
jcarp
i want to widen my 06 wheels 2" out back but i'm worried about using spacers and the ride plus i dont want them to look to far out from behind bc of the way the fenders do when they go down.
Old Mar 1, 2006 | 01:23 PM
  #45
cms-35z's Avatar
cms-35z
Here is a link to the track wheel thread. https://my350z.com/forum/showthread....02#post2155002
Old Mar 1, 2006 | 05:19 PM
  #46
davidf's Avatar
davidf
Widening wheels has been around for ages, don't worry bout the negitive hype, in my early days while most of ya'll were kids we widened 8 inch Corvette and Camero rally wheels all the time, never a problem. By the looks of your wheels you got a great deal on a great looking job.
Old Mar 2, 2006 | 04:34 AM
  #47
Silkk's Avatar
Silkk
Ok, I'm going to switch gears here and not argue how safe/not safe this is to how economically smart it really is. Just for sake of another argument not to do this.
Widening 4 Wheels = $170 per x 4 = $680
2 Sets H&R Spacers = $150 per x 2 = $300
2 315/35/17 Tires (look like Goodyear Eagles?) = $283 per x 2 = $566
2 275/xx/17 Goodyear tires (for front?) = $211 per x 2 = $422
Unmounting of Tires to ship, Mounting of new tires = $100
This comes to roughly $2068. Not to mention the hassles of unmounting/mounting new tires. I'm sure you could have found some decent staggered 17 or 18 wheels (with 9.5-10.5 rear width) that are much lighter than stock, along with the same tires, for about the same price; maybe a little more, but maybe a little less? And your car wouldn't be sitting on OEM rims so it would look a little different.
Only way I can justify this is if you are really hell-bent on being a "sleeper" car.
Old Mar 2, 2006 | 05:24 AM
  #48
cms-35z's Avatar
cms-35z
Unless you want affordable light wide wheels.
That is the only reason I can see doing this with the track rays wheels.
It would cost more than you quoted for a set of 18x9.5 or larger wheel that weights in the range 19lbs each. And your still going to have to buy new tires, so you can't factor that into the cost of the wheel mod.
Most wheels I find in that size that cost 1,200 or below seems to be 25lbs - 31lbs.
Old Mar 2, 2006 | 05:46 AM
  #49
Zilvia's Avatar
Zilvia
so can you do this widening to any wheel........... like the new 19 forged Rays for the G35
Old Mar 2, 2006 | 06:56 AM
  #50
JimRHIT's Avatar
JimRHIT
A perfect candidate.
Old Mar 2, 2006 | 09:21 AM
  #51
Gooey's Avatar
Gooey
Just buy some 06 track wheels 19x10 lightweights
Old Mar 2, 2006 | 09:34 AM
  #52
35oZephyR's Avatar
35oZephyR
That looks insane from the back...
And I'm not sure how safe that welding is, but I'll tell you this:
I'd rock those before I'd trust SOME of the questionable wheels I've seen on these boards.
Old Mar 2, 2006 | 09:40 AM
  #53
Zilvia's Avatar
Zilvia
id like the look of the Gs better
Old Mar 2, 2006 | 09:46 AM
  #54
Silkk's Avatar
Silkk
He didn't even widen track wheels. He widened already heavy 17" wheels...
Old Mar 2, 2006 | 11:27 AM
  #55
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I know where you're coming from. I'm somewhat well versed in materials science and I understand what you're saying. I don't mean to say that "anyone who welds a wheel together and makes it wider will be fine."
I'm saying as long as it's done correctly it should be fine. By correctly, I mean by addressing the different topics you're talking about, specifically misalignment.
I believe as long as the wheel is well balanced and aligned properly when the welding is done, it should be fine. Of course an impact (pothole etc) may crack the rim along its defects, and there are most likely more defects at or near the welds.
Heat treatment is of course great for relieving stresses by allowing the dislocations and vacancies to diffuse away from each other. However, I was referring to tensile stress when I said it should be "fine". Unless your car is NUTS and putting down a rediculous amount of 1000+ HP, I don't think the amount of torque a regular automobile can put down will ever reach the tensile limits of the weld.
Even if you do reach the tensile limits of the weld, you should know that the weld will undergo plastic deformation, making it stronger, before it fractures. YES cyclic loading and fatigue are a concern. But think about it. What is the typical cyclic limit of most metals, like 10^6 cycles (correct me if I'm wrong, it's been a while for me)? How many decades do you think it would take to reach that limit? I'd be more concerned with my rear differential, axle, transmission, etc WAY before the wheel ever broke. Hell, even the lug nuts and studs are more of a concern than this weld, because they are directly receiving torque.
That's all I'm saying. I'm NOT saying that this won't create a weak link in the wheel. It probably will, ESPECIALLY when hitting potholes. But if the job is done well, the rate of fractures won't be any higher than a typical cast wheel. As you know, cast wheels are prone to having tons of dislocations, deformations, and vacancies which also lead to their cracking. Not everyone can buy forged...
I like this refreshing debate we're having
Old Mar 2, 2006 | 12:53 PM
  #56
cms-35z's Avatar
cms-35z
That wasn't my point. You were making a reason why a person should not do this, and I was making a reaon why one might justify it.
Old Jul 16, 2006 | 04:10 AM
  #57
punish_her's Avatar
punish_her
sorry to resurect a dead thread ...
For all of you who've had questions about weldcraft on the quality of the welds, the wheels, and whether or not they know what they are doing, they wave been in business over 30 years.
I was curious because I remeber in 1990 my dad had a 69 Camero blown 350 W/ NO2 850 +whp that had the wheels widdened. I just got off the phone with them in KY, and he said weldcraft did them. It was done under the origonal owner, stew something or rather ( he couldnt remeber), and their work was garunteed to run true when done and balanced out with no issues. They held up after many runs and acouple of pulls raised the front end. If that aint rotationa torque then what the f@ck is?
Yeah I would be skeptical if this was a company thats been arround for a couple of years; but 30 years yeah I think they know a thing or 2 about what they are doing.
Old Mar 31, 2008 | 05:54 AM
  #58
cms-35z's Avatar
cms-35z
Bump to see if there were ever any issues with these wheels over time.
Old Mar 31, 2008 | 07:58 AM
  #59
Get_Zwole's Avatar
Get_Zwole
Unless a really shoddy job has been done, it should be fine.
There was a discussion about this before, someone widened the stock 05 Ray's wheels on the 350z.
agreed i am a welder so unless its a terrible weld then the other part of the wheel will break before the welds will. looks great man.
Old Mar 31, 2008 | 11:10 AM
  #60
Chef-J's Avatar
Chef-J
Booooosstt!!
is that safe??
