+12mm offset OK for the rear?
Old Jan 30, 2006 | 07:18 AM
B. Treluyer's Avatar
B. Treluyer
Question +12mm offset OK for the rear?
Hello Everyone,
I'm new and I'm worried because a local dealer ordered a set of Gram Lights 57C
for me. They said fronts are 18x8.5 +30 and rears are 18x9.5 +12. I questioned the +12 and they said it will fit without any rubbing. I've searched every forum
site and nobody has this setup. I plan on running w/245/40/18F and 275/40/18R
and I hope it's OK without any adjustments.
Please help,
Super GT Fan
PS My car is stock 03' Performance and this is the only mod I'm doing.
Old Jan 30, 2006 | 07:56 AM
Interesting. The standard NISMO rear wheel is 18x9.5 with a +30mm offset. And you are talking about a +12mm offset. So your wheel will sit 18mm closer to the fender than the NISMO wheel. That might be a tight fit.
Old Jan 30, 2006 | 08:00 AM
B. Treluyer
Actually according to offset calculators, it will extend out 37mm (about 1.4 in) from stock.
Old Jan 30, 2006 | 08:36 AM
anotheraznguy's Avatar
anotheraznguy
a 9.5 + 12
will work ok...
in essence it is a 10 +18
and i know a few guys that run that without too much issues.
you can run a 275 and may or may not need a roll depending on how low you are and how much rear camber you have.
Old Jan 30, 2006 | 08:40 AM
BlackoutZ's Avatar
BlackoutZ
I am running a +22 offset in the rear with a 18-9.5 and it is absolutly flush with the fender. This is the best setup in my opinion. I have pics of it in the wheel and tire section.
Old Jan 30, 2006 | 09:13 AM
B. Treluyer
Originally Posted by anotheraznguy
a 9.5 + 12
will work ok...
I plan on keeping everything else stock, so I don't want to change the suspension or
camber settings. I'm just worried the tires will stick out too much.
Old Jan 30, 2006 | 09:25 AM
Driven1's Avatar
Driven1
Professional
Here is a pic of my car with 20's if it helps. they are a 20x11 rear 34 offset. The front is a 20x9 29 offset (stock Enthusiast suspension). My buddies at Auto Effects say to be careful with the +12 because they will probably stick out. They don't sell that particular wheel but they said most wheels thay do in an 18 on a Z should be about a 25 offset in the rear. If you have any other questions PM me and Ill give you their number and they can help you figure out what the deal is.
https://my350z.com/forum/mid-atlantic/168107-pics-from-yesterday-s-meet-in-columbia-md.html
Old Jan 30, 2006 | 10:43 AM
mavtais's Avatar
mavtais
Good job! I don't think there are any suspension set-ups out there that truly enhance your handling anyway. I agree with you totally: Keep it stock, but don't give your car "beaner wheels"
Old Jan 30, 2006 | 10:46 AM
reyes5912's Avatar
reyes5912
I have a that off set on my FNO1R-C but they are 17s. I belive that it is a +15 on a 17x9 and a +12 in the rear on a 17x10. I have no rubbing issues but I have my fenders rolled. I run 255/40/17 on Falken ST-115 in front and 275/40/17 on Falken RT-615 in the rear. I had my fenders rolled to fit my 19s' for 295/35/19 BFGoodrich KDW. I love that look so I hope that helps you.
Old Jan 30, 2006 | 11:06 AM
bilinghm's Avatar
bilinghm
18X9.5 +15 fits with a 11" section tire. Not lowered, unrolled fenders. Any wider tire would be problems. Be very careful with the tires you choose unless you are willing to mod the fenders.
