What is this? Extra stud on front wheels.
Old Feb 5, 2006 | 06:24 PM
Roger V's Avatar
Roger V
Default What is this? Extra stud on front wheels.
When I was installing my new wheels I saw this extra stud. It was only on the front two wheels. It wouldn't let my wheels go on so I took it off. What is it for?
Old Feb 5, 2006 | 06:29 PM
kalima275Z's Avatar
kalima275Z
It's in your manual. The studs are there because the rear wheels are a different size than the fronts. It's to ensure that Z owners put the right wheels in the front and not on the back.
Old Feb 5, 2006 | 06:33 PM
Roger V's Avatar
Roger V
I didn't even think about looking in the manual. Thanks for the info.
Old Feb 5, 2006 | 07:06 PM
PDX_Racer's Avatar
PDX_Racer
RTFM! That's what it's for!
Old Feb 5, 2006 | 07:11 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
forgot to tell you that Roger
Old Feb 5, 2006 | 07:25 PM
Inovashn's Avatar
Inovashn
wow someone with that many post you think maybe they would know about the search function.
Old Apr 6, 2022 | 11:41 AM
Asher king's Avatar
Asher king
how tf did you get it off? Just cut it or what
Old Apr 6, 2022 | 02:20 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Unbolt it.
Old Apr 6, 2022 | 07:56 PM
terrasmak's Avatar
counter clockwise with a 10mm wrench or socket will remove it. Cutting it will also work, take a video if you try
Old Apr 7, 2022 | 06:44 AM
i8acobra's Avatar
i8acobra
Hit it with your purse.
Old Apr 7, 2022 | 08:13 AM
Heel Til I Die's Avatar
Heel Til I Die
So much win.
Old Apr 8, 2022 | 10:33 AM
Asher king's Avatar
Asher king
bet ill try
Old Mar 4, 2024 | 10:15 AM
Skippycruz's Avatar
Skippycruz
what is the size of that bolt bro I drive a 350z manual and I lost that bolt
Old Mar 4, 2024 | 10:42 AM
travlee's Avatar
travlee
Master
its not needed... its there to keep you from accidentally putting a rear wheel on the front
Old Mar 4, 2024 | 11:20 AM
Heel Til I Die
Might want to double-check that. A few extra grams might throw off that corner balancing...
Old Mar 4, 2024 | 03:47 PM
MicVelo's Avatar
Ah yes, the old "corner balance rot from the placement stud" syndrome. Well, a set of Ohlins external reservoir coilovers oughtta fix that right quick.
