takin 2 pc rims apart???
Old Feb 5, 2006 | 08:42 PM
tuner4life's Avatar
tuner4life
Default takin 2 pc rims apart???
well i have a set of ro ja r2-5's, which are 2 pc rims....there is a decent amount of brake dust on them and is impossible to clean between some of them nooks and crannies...so my question is, is it safe to take the rims apart and get them all cleaned up???
Old Feb 5, 2006 | 09:33 PM
350Zteve's Avatar
350Zteve
Can your rims be taken apart? Most two piece wheels consist of a center peice which is WELDED to the barrel. If your's are bolted in, then yes, you can undo the bolts and take them apart. Just use some loctite when you put them back together.
Old Feb 6, 2006 | 07:16 AM
Yes.
a. Take the wheels apart.
b. Clean.
c. Assemble using a torque screwdriver.
d. Add tires.
e. Balance.
Old Feb 6, 2006 | 07:26 AM
Chris@DTD's Avatar
Chris@DTD
NO!
Only a trained professional should take the wheels apart!
End of story.
Old Feb 6, 2006 | 02:10 PM
tuner4life's Avatar
tuner4life
ok well i just called a wheel shop and they said not to take the rim apart...and as far as gettin the brake dust off, they recommended the household cleaner soft scrub...have any of u guys had experience using it???
thanks
Old Feb 6, 2006 | 02:40 PM
mgl's Avatar
mgl
soft scrub?! i would not use soft scrub on my wheels.
i use nothing other than just car wash soap and water. try using qtips for the hard to reach parts.
Old Feb 6, 2006 | 02:44 PM
'04blackz33tour's Avatar
'04blackz33tour
i have same rims, how can u get replaxement lips
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
