Torquing your wheels
Old Feb 20, 2006 | 09:35 PM
adrianko43's Avatar
adrianko43
Default Torquing your wheels
When you guys put on your wheels, how much do you torque the lug nuts? Something really bad almost happened today.
So... I was driving on the freeway, and the car started to shake, but i shrugged it off, thinking it was the uneven pavement. Then i started thinking it could be my wheel coming loose. I pulled off the freeway, and checkd my wheel, and confirmed my worst nightmare. When i looked at the wheel, there was only 1 lug nut holding on my wheel I am so thankful i pulled over in time and that last one didnt come off, i dont even want to think about what would have happened if my wheel came off. Well, i got new hub bolts since the other ones were stripped, and i got new lugs since 4 of them are somewhere on the freweay.
One other time after coming back from a track event at buttonwillow, i checked my lugs and i could loosen them with my fingers. Ever since then i retorque them after every run; they tell us to do this while we'rer there, but i was stupid. Well, you live and you learn.
Yeah so, i just wanted to know if i didnt torque my lug nuts enough (90 ft-lbs), of if switching back and forth between rims so often has caused the lugs to come off easier (i switch from my volks to my 18s when i go to the track). Any opinions or feedback? I dont want this to happen again. Im very paranoid right now, so im probably going to check my lug nuts every morning or something.
Old Feb 20, 2006 | 09:55 PM
adrianko43's Avatar
adrianko43
whoops, i just read the thread up there, and someone said 90 is good. Then can someone explain why my wheel came loose?
Old Feb 20, 2006 | 10:19 PM
InZomniac's Avatar
InZomniac
Possibly not on true. Secondly not torqued enough. Lastly...
Gremlins
Old Feb 21, 2006 | 12:14 AM
gt3's Avatar
gt3
The same thing happened to me but I think I just forgot to tighten the wheel after putting it on. Sorry I am not sure what happen in your case. I was lucky as well because I found the passenger rear wheel held only by 2 lug nuts. I think 90 ft-lbs is more than enough. To be safe, I ususally check the torque again after I tighten the lug nuts and drive the car for a while. Dunno if you do the same.
Old Feb 21, 2006 | 07:31 AM
The torque specifications are in the maintenance manual. Do you have a maintenance manual?
Old Feb 21, 2006 | 07:34 AM
cj350's Avatar
cj350
Scary
Old Feb 21, 2006 | 07:47 AM
Kolia's Avatar
Kolia
More than 90lb is a bit much. Put unecessary strain on the studs.
Check them often, check them again...
Old Feb 21, 2006 | 08:01 AM
Chris@DTD's Avatar
Chris@DTD
An overtightened lug will also loosen. Be sure that your torque wrench is calibrated as well as torquing in a star pattern. Sneak up on the click, don't go past it.
Chris
Old Feb 21, 2006 | 08:08 AM
MyNismoRoadster's Avatar
MyNismoRoadster
It could also mean someone was trying to steal your wheels or sabotage your car. : shrugs :
Old Feb 21, 2006 | 08:16 AM
sq40's Avatar
sq40
I always Tighten to 100lbs.
Obadabot
Jun 18, 2023 11:31 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
