Simple wheel question.
I want to get the Volk LE37 gun metal with polished lip wheels, 19x8.5 +22 offset with 243/35/19 F, 19x9.5 +22 offset with 275/35/19 R. I will drop my car with Eibach Springs (pro kit) at the same time.
1. Will this set up give me that cool deep-dish look?
2. Will I run into any problems such as rubbing, traction, camber, or anything else that I am unaware of, now or later on in the future if I drop my car using the Eibach Pro Kit?
3. I heard that with the Eibach Pro Kit, you don't need to get a camber kit and that you just need a new alignment at your local tire shop because it is only 1" drop. Is this true?
Thanks for your help! Greatly appreciated!
1 - No. To get a lip on a 9.5" LE37 you need a +12. The other option is a 10.5" +22. Either way, you won't really have a lip on the front and rear will be about 2". There are a ton of pics out there if you do a search.
2 & 3 - Only issue will be the alignment. Chances are very good you won't be within stock spec. Some people like the extra handling of increased negative camber and some want even tire wear. You have to determine where to draw the line.
So does that mean I don't need to buy a camber kit? Can I just take it to my local shop and have them fix it back to stock spec using my stock arms after I lower 1"?
