Can Anyone Explain "Rolling the Fenders"?
Old Mar 3, 2006 | 07:49 AM
thrill350z's Avatar
thrill350z
Default Can Anyone Explain "Rolling the Fenders"?
hey can anyone full explain to me what they mean by "rolling the fenders"? why this would be done, how much a body shop would charge for this and what it involves?
Old Mar 3, 2006 | 07:52 AM
"Z"orilla's Avatar
"Z"orilla
Read my thread, it is dicussed in there. You can also enjoy the pics of other member's rides!
https://my350z.com/forum/showthread.php?t=171556
Old Mar 3, 2006 | 08:42 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Yep just look for my ghetto microsoft paint drawing of the fenders lol
Old Mar 3, 2006 | 07:32 PM
jinsei888's Avatar
jinsei888
haahaa
Old Mar 5, 2006 | 11:54 AM
thrill350z's Avatar
thrill350z
I was looking for more or an explaination why people would roll the feners. how it is done, and how much it would cost
Old Mar 5, 2006 | 12:39 PM
The objective is too put wider wheels on the car. The limiting factors are inside clearance (suspension components) and outside clearance (fenders).
Old Mar 5, 2006 | 12:47 PM
Endless Shock's Avatar
Endless Shock
Smile
Well lets see... Im sure people on this board do it because they have an agressive wheel offset and wider tire combination that go beyond the rear fender... I have SF Challenges 19x9.5 +28 and 19x10.5 +23 wrapped with BFG KDW2's, looking straight down from the top most part of the rear fender I can see that it "sticks out" a little bit... So that means when I get my coilovers I need to roll them (and maybe have them pulled)...
Tools needed are:
Fender rolling tool
Heat gun (not a blow dryer)
Fender rolling is done by heating the area with the heat gun then folding the lip on to itself... Heat is needed so the paint doesnt crack... Patience and experience is the key to good fender rolling...
Depending on where you go it may range from $50-$200...
Check your local forum to see how has had it done and ask to see if you can meet them and see what fender rolling is all about...
Well I hope that helps...
Old Mar 5, 2006 | 07:11 PM
xtrememan315's Avatar
xtrememan315
The other option is to cut the inner part of the fender. This is easier and more body shops will do it because there's no chance of the paint cracking since your not bending the metal. All you have to do is cut the right amount off the inner part of the fender and make sure to use undercoating or paint the area that was cut to prevent rusting. I got this done to fit my 10.5" rears and it only cost $70. Takes less than an hour and just as good as "rolling"
Old Mar 5, 2006 | 07:36 PM
thrill350z's Avatar
thrill350z
good info! do u think ill need to roll or cut my fenders with 20x10 in the rear with 275/35/20 and eibach pro kit 1" drop?
Old Mar 5, 2006 | 08:29 PM
xtrememan315
I would just cut, easier/cheaper/less risky for paint
Old Mar 5, 2006 | 10:41 PM
1G-350Z's Avatar
1G-350Z
+1
Old Mar 5, 2006 | 10:55 PM
Sean's Avatar
Sean
it isn't risky if you use the special paper, you can get it all over, even some convinence stores, just ask for xtra wide rolling papers at the 7-11
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
