Tires: Bridgestone Potenza vs. BFGoodrich g-Force T/A KDW 2
Old Mar 12, 2006 | 04:46 PM
Suvlaki's Avatar
Suvlaki
Exclamation Tires: Bridgestone Potenza vs. BFGoodrich g-Force T/A KDW 2
Curious. According to the specs, the BFGoodrich is a better tire, aside from being a bit noisier. It has the same traction, but a higher treadwear rating. Why, then, is it so much less expensive than the Potenzas? Is there anything else you should be looking in to when choosing your next set of tires? Which set is the best set for my Touring Z, because I have a heavy foot. My '06 Z came with the Potenzas stock from the dealership, so I am probably going to replace them with the same tire. However, the BFGoodrich tires look like a better buy. What do you guys think..?
Bridgestone Potenza:
http://www.tirerack.com/tires/tires....h=true&index=0
Dry Traction Rating: 9.2
Wet Traction Rating: 8.7
Ride Comfort: 7.8
Noise Comfort: 7.6
Wear: 6.6
Treadwear Rating: 220
Traction Rating: AA
Temperature Rating: A
Price: $225.00/tire
BFGoodrich g-Force T/A KDW 2:
http://www.tirerack.com/tires/tires....h=true&index=4
Dry Traction Rating: 9.3
Ride Comfort: 8
Noise Comfort: 6.8
Wear: 7.8
Treadwear Rating: 300
Traction Rating: AA
Price: $156.00/tire
Specs taken from http://www.tirerack.com
Old Mar 12, 2006 | 04:51 PM
Vamos_Rafael's Avatar
Vamos_Rafael
you dont want to get teh RE040's again...
please ... you check the ranking on tirerack for the RE040's??
they are the 2nd worst tire in the catagory!
if you want bridgestone tires check out S03 Pole-Position or RE050/RE050A
Old Mar 12, 2006 | 06:34 PM
Suvlaki's Avatar
Suvlaki
My bad, I linked the wrong tire. The ones that came stock w/ my car are the RE050A's.
Old Mar 12, 2006 | 06:49 PM
TheProfessional's Avatar
TheProfessional
Potenzas are more because they are OEM spec. People are in the mindset they have to purchase the same tire to be "compliant" and the dealerships have to replace the same tires when needed.
Basically tire mfrs bid on the opportunity to provide OEM tires to new vehicles, the lowest bidder wins, they ship tires by the TRAIN LOAD to the final assembly, then 6 months later they see the benefit by jacking up the price for consumers to replace them.
If you don't believe me, look at General Tire Co. They lost out in the last 2 years on these bids and they have had to expand their product offering AND INCREASE QUALITY (mildly) just to keep up with the other companies.
The BFG KDW2 is superior, dont fall into the price point/quality fallacy.
Old Mar 12, 2006 | 07:00 PM
skeleton jack's Avatar
skeleton jack
At discount tire, the same potenza tire cost $320 each. i only needed 2 rear tires and almost sh*t myself when the final price with warranty was over $800. i went with the BF kdw2's. But the car is alot more wiggly with those tires back there.
Old Mar 12, 2006 | 08:41 PM
Armitage's Avatar
Armitage
I switched to the KDW-2's and I love them. They are louder than the RE040's, but the sidewall is much stiffer and turn-in seems better. Plus they were $160/tire from Tire Rack in the stock sizes.
Old Mar 12, 2006 | 09:23 PM
krnazngimchi's Avatar
krnazngimchi
Default Cool Cool
The only thing is that the BF Goodrich tires have pretty bad wet weather traction ... pretty bad but I'm willing to sacrifice a little wet weather grip for awesome dry weather grip aren't you?
Old Mar 12, 2006 | 09:31 PM
Armitage's Avatar
Armitage
Uhhh... not the KDW's. Your thinking of the KD's. K = Killer, D = Dry Traction, W = Wet Traction
The KDW's are designed for all weather conditions except ice and snow. Their wet traction is up there with GSD3's from Goodyear and S03's from Potenza.
Old Mar 13, 2006 | 05:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive had em both, KDWII's by far...
Old Mar 13, 2006 | 05:47 AM
Vamos_Rafael
try kumho MX - by far the best valued max performance summer tire...
*just a suggestion*
Old Mar 13, 2006 | 09:36 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
In addition to being reliable on the street, sticky on the track, ample traction in the rain, the BFG KDW-NT has the sickest looking tread out there. Combine it with a decent price, and I probably wouldn't ever choose a different tire for a street car.
Old Mar 13, 2006 | 09:41 AM
JasonZ-YA's Avatar
JasonZ-YA
I just replaced my rears with Remington ESSENZA 210 TYPE R on my rears at they are way better traction grabbers than the stock potenza's. I found them decently priced locally and love the tread pattern loook as well.
Old Mar 21, 2006 | 05:53 AM
sq40's Avatar
sq40
I have been running the Falken Ziex-512s for a month now in snow and rain and can readily recommend them as a good replacement tire too.
Old Mar 21, 2006 | 07:23 AM
dlmkr1's Avatar
dlmkr1
I have the Goodyear F1 GSD3s. They improved the handeling and ride dramatically. Look cool too! If you really shop around you can get a decent price but they are a bit steep.
_koubie_
Sep 20, 2015 06:34 PM
hardkicks
Sep 20, 2015 12:28 PM
