SF-WINNING on Silverstone roadster: Gunmetal or Silver?
Old Mar 17, 2006 | 02:44 PM
  #61
Zquicksilver's Avatar
Zquicksilver
Originally Posted by BhashaZ
Just an FYI: if you're going with 9.5" wide front, you can go with either +29 or +19, and both will have the exact same lip, but one is tucked in more, while the other one is pushed out more. The reason is, the +19 is a "front" wheel, and the +29 is technically a "rear" wheel".
BhashaZ... FYI also... Even though the "rear 9.5 @+29"would be absolutely perfect for the FRONT, there's a VERY good chance it will not clear the BREMBO or other BBKs because of the shallow spoke design. Like I mentioned in a post earlier... while doing my BBK research and wheel research I found the spokes are different. There is more HUB in front than rear, giving you greater caliper clearance.
Without doing a lot of reading, this is what a 9.5@+30 looks like in front with a 275 on it. Just glance at the pics... http://www.sportcompactcarweb.com/pr.../0404scc_350z/
Dildorado, if you want a truly staggered look, then go with the 8.5/10.5 setup. If you want equal lip F/B then go with what you did. But keep in mind, your front will stick out slightly more than your rear, visually speaking.
Zquicksilver
ps this is old stuff, but still informative...
http://www.350zmotoring.com/forums/s...0&page=1&pp=15
https://my350z.com/forum/wheels-and-tires/86159-f_a_t_t_e_s_t-tires-on-a-19-rim-5.html
Old Mar 17, 2006 | 03:37 PM
  #62
Vick781's Avatar
Vick781
Damn Tim's Car look HOT!
Old Mar 17, 2006 | 03:56 PM
  #63
BhashaZ's Avatar
BhashaZ
Zquicksilver
https://my350z.com/forum/showthread.php?t=86159&page=5
Good point about the Brembo's...I totally forgot that he had them! Either way, he's already done ordering.
But Dildorado, as Zquicksilver has mentioned, the setup that you ordered (and that I have on my car) is going to have the front pushed out more than the rear, creating a bull-dog-like stance. You can fix this by getting a 5mm spacer on the rear, which balances out the setup perfectly IMO.
JjL
East Canada
Jun 12, 2019 03:04 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
hardkicks
Sep 20, 2015 12:28 PM
