Whats a man to do?
Old Mar 21, 2006 | 08:51 AM
sq40's Avatar
sq40
Default Whats a man to do?
I search high and low for a set of Wheels that I like enough to buy and when I go to buy them I find they only come in a +42 Offset..
Life just sometimes Sux..
Old Mar 21, 2006 | 09:12 AM
ZRaven's Avatar
ZRaven
Why not user spacers
Old Mar 21, 2006 | 09:14 AM
sq40's Avatar
sq40
I am a bit nervous about them.. I think a 5mm would work.. But not sure..
Old Mar 21, 2006 | 09:22 AM
sq40's Avatar
sq40
I can get a 6.3mm Spacer set for $30.. Will stock studs work OK there?
Old Mar 21, 2006 | 09:26 AM
Silkk's Avatar
Silkk
You should probably space out +42 offset wheel quite a bit more than 5-6mm...
You want to be in the 20-30 range ideally, depending on wheel width. I've even seen people going as low as 15 offsets on some wheels.
I spaced out the G35 RAYS on my Z 15 and 20mm with KICS spacers and they are 30-33 offsets to begin with. Looks perfect.
No problems either. What are you wary about?
Old Mar 21, 2006 | 09:48 AM
sq40's Avatar
sq40
Good Info There. Should I go with a Longer Stud and Spacer "Plate" or those bolt on jobs like the H&R? I can get the former in 20mm for $180ish and the latter will run about $250ish.. Just buying 6mm Spacer with Stock Studs will only cost me $60, but may not look as good?
What about brake caliper clearance? I have non-brembros..
Old Mar 21, 2006 | 02:41 PM
pingbling23's Avatar
pingbling23
i'm running wheels with a 42mm offset without spacers, unless nissan put spacers on there without charging me, which i highly doubt.
Old Mar 21, 2006 | 06:49 PM
sq40's Avatar
sq40
What wheels? Do you have any Pics?
Thanks,
Old Mar 21, 2006 | 07:47 PM
Casanova's Avatar
Casanova
Old Mar 22, 2006 | 11:13 AM
sq40's Avatar
sq40
Well.. Im SOL.. No place on the Internet has the wheels I was trying to buy.. Why is it so hard to get 17x8 wheels that look good?
Old Mar 22, 2006 | 02:35 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Cuz 17X8" is a damn Civic, Integra, Celica, RSX, weaksauce size-so you'll likely find very ghey offsets. Man-up and get some 9.5" + wide wheels/rubber like a Z should have and offset in the 20's. You may not be happy, but at least we wont laugh at you....
Old Mar 22, 2006 | 02:58 PM
sq40's Avatar
sq40
Great, Send me a check for a Grand to make up the difference and i will do that Alberto. Since we are such good friends i know you don't want anyone to laugh at me.
Old Mar 22, 2006 | 05:14 PM
Alberto's Avatar
Alberto
Cranky FI Owner
The above was a joke, this is not: if you cant do it right why do it at all? Just stay stock or do some spacers on stock with wider tires to hold you off.
Old Mar 22, 2006 | 05:23 PM
pingbling23
Thanks,
They are 17x7.5 42mm offset. The wheels are msr 122. Im selling them for $250 if anybody wants them. I know alot of people like to have a set of track wheels.
Old Mar 22, 2006 | 05:52 PM
sq40's Avatar
sq40
Thats cool man.. I am considering a set of 18's and tires.. i really like the ride of the 17 with the 50 series on them.. but if I cant get anything nice, I will just save up for something larger.
Old Mar 22, 2006 | 06:31 PM
Alberto's Avatar
Alberto
Cranky FI Owner
You look into like Axis Hiro's? You can get them staggered in 18" for under $1300, look good imo and nice and wide....
InternetABYSS
Sep 4, 2002 11:11 AM
sammythebull
Sep 3, 2002 12:53 AM
markt71Z
Aug 31, 2002 11:52 PM
