Proper offset for 9.5" wheels up front
Old Apr 1, 2006 | 07:30 AM
BadBlood's Avatar
BadBlood
Default Proper offset for 9.5" wheels up front
I'm looking to get a set of wheels soon. Hopefully 18 or 19 x 9.5 all-around. My question is this: Is there an offset that will work ok for the front and rear on a 9.5" wheel.
Most of the wheels I'm seeing are +30 to +35 offset for rwd. Will these work OK? Im concerned by the amount of wheel that may extent out of the well.
BTW : Sorry for the newb question. I did check the fittment calc that stickied to the forum, and it shows -17mm to strut and +33 on the outside... My real question, has anyone run this setup and did it rub?
I'd be looking to run something around a 245/40 or 275 series rubber.
Old Apr 1, 2006 | 07:43 AM
bstansbu's Avatar
bstansbu
I ran with 8.5x19 front with +23 offset and 9.5x19 rear with +24 offset. No rubbing at all. rear were 275-35-19 and front were 245-35-19. No problems. BEN
http://www.zmodified.com/gallery/dis...lbum=301&pos=7
Old Apr 1, 2006 | 07:51 AM
350dgrz's Avatar
350dgrz
Chris from F1motorsports should be able to help you. Btw, I have 19" X 9.5" +19 in front and 19" X 10.5" +29 in the back on 245/275 SO3s
Old Apr 1, 2006 | 10:18 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
first question - why run the same size all around? Do you know enough about tuning the rest of the suspension to actually get this to work succesfully?
Old Apr 1, 2006 | 12:08 PM
Alberto's Avatar
Alberto
Cranky FI Owner
+22 - +30 would work-depends on what look your going for....
Old Apr 1, 2006 | 09:14 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I am running 18x9.5 +30 all the way around, the fronts fit perfectly, I have pics here
http://www.hypersprite.com/auto/picture-z-017
I don't know if you want to go any lower offset than 30 up front, they are pretty flush. O also don't know if you can get a +35 on there, it's a bit tight. The backs you could go with a +22 if you were looking to flush them out as well.
Chris
Old Apr 2, 2006 | 08:22 PM
phile's Avatar
phile
Has anyone found a really good racing setup with particular sizes, widths, and suspension?
Old Apr 2, 2006 | 08:31 PM
changsw's Avatar
changsw
I would go 9.5/10.5 +22 all around (offsets depending on the type of wheel you get of course). I hear some people who get 8.5/9.5 regret it and would have rather gotten the 9.5/10.5. Trust me, I was one of them. And yes, Chris at F1 Motorsports in N. Hollywood, CA will help you out. He'll probably tell you the same thing I just did. The 9.5/10.5 will look GOOD on your Z. And no, no rubbing issues with mine.
Old Apr 2, 2006 | 08:39 PM
phile's Avatar
phile
What kind of handling characteristics does this promote? How is off-the-line acceleration? Although I don't drag my car, how would a 1/4 mile be affected?
One last question, what about 9" and 10" :P
Old Apr 2, 2006 | 08:47 PM
changsw's Avatar
changsw
Because I don't drag myself, I wouldn't know about 1/4 mile times. As for handling, I think it's great. The car feels very planted on the road when you do quick turns and stuff. 9.0/10.0 is another possiblity, but if you got the money, I would go 9.5/10.5. Just looks better in my opinion.
Old Apr 2, 2006 | 09:44 PM
350Zteve's Avatar
350Zteve
I run an 18x9.5 up front with +27 offset. Clears my 265's easy.
Depravity
Oct 1, 2015 04:49 PM
