255/45/18's on the back...good idea!!
Old Apr 4, 2006 | 06:41 PM
MyZ4U2C's Avatar
MyZ4U2C
Thumbs up 255/45/18's on the back...good idea!!
My Bridgestones finally wore down (33K miles) so i ordered a set of 255/45/18 Sumitomo's for the rear. What a difference!! In addition to looking much more substantial (the view from the rear with the awesome looking tread on the tires is very nice!!), but the car handles even better!!
If anyone is looking to upgrade the tires on the stock rim, go for this size tire on the back. The tire isnt so wide that it bulges off the side of the stock wheel and it improves the look and handling a lot.
Old Apr 4, 2006 | 06:45 PM
tmounk's Avatar
tmounk
Have any pics
Old Apr 4, 2006 | 06:47 PM
MyZ4U2C's Avatar
MyZ4U2C
Not yet...i just got them on this eve..i'll take some pics and re-post tomorrow.
Old Apr 4, 2006 | 07:21 PM
rockinbboy's Avatar
rockinbboy
Do you think the tires you got will fit stock 18" anniversary rims? I will get 255s after my tires wear down.
Old Apr 4, 2006 | 07:44 PM
MustGoFastR's Avatar
MustGoFastR
Will this be ok on cars with VDC, though?
Old Apr 4, 2006 | 07:50 PM
Ztalker's Avatar
Ztalker
i once bought a set of sumitomos and had to return them because of vibrations .... got bf goodrich kdw instead.
Old Apr 4, 2006 | 07:56 PM
MyZ4U2C's Avatar
MyZ4U2C
Yes they will fit stock Anniversary rims no problem. My car has VDC and no problems whatsoever. The tires are great....but im not pushing Sumitomos specifically here, im just pushing the tire size for when folks upgrade.
Old Apr 7, 2006 | 06:05 AM
Pedal Pusher's Avatar
Pedal Pusher
I have been running 255/40-18 rear tires on 9" SSR Comp-H wheels for the last 3,000 miles and all is well. I have a G35 with Tein S-Techs.
Old Apr 7, 2006 | 07:32 AM
MustGoFastR
Debating which is better, 255/40 or 255/45... 45 is closer to stock than the 40; just slightly bigger. Running a 40 will be underdriving the car slightly, giving a little help to acceleration and less sidewall to flex, but the tire may look smaller and the speedo will be off more.
Old Apr 7, 2006 | 08:26 AM
Pedal Pusher
Maybe I should have told the rest of the story. I have Potneza S-03 Pole Position tires with 245/40-18 front and 255/40 rear on 9" SSR Comp-H wheels. The 245/40 front and 255/40 rear give the car very good oversteer/understeer balance at the limit. I also have adjustable upper "A" arms on all four corners so I can completely control my toe and camber settings.
Old Apr 7, 2006 | 10:00 AM
MustGoFastR
I'm considering the same tire setup (with Falken Azenis 615s) on the Track Rays rims and my Nismo S-Tune suspension. Still debating between the 40 or 45 series tire in the rear...
07ZEKE
Aug 23, 2021 09:15 PM
Alexreyes
Sep 30, 2015 11:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
