Talked to Chris from F1 Motorsports
Old Apr 5, 2006 | 11:00 AM
kvon's Avatar
kvon
Default Talked to Chris from F1 Motorsports
and he is REALLY worried that the Work VS-XX 19X10.5" with a +29 offset won't work for the rear because i have brembo's
can anyone justify this from experience?
I NEED HELP ASAP.
Edit/Delete Message
i have a G35 btw
Old Apr 5, 2006 | 11:06 AM
ASTIG_Z's Avatar
ASTIG_Z
Did you order them to clear brembo's? I have them ordered from Rick from STATUS, he said he'll hook up to where they can get them to clear BBK. I ordered 19X10.5 in the rear also.
Old Apr 5, 2006 | 11:11 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
you can custom order to clear your BBK. BTW, i have 10.5 with 29 offset also and they clear my Rotora. Brembo is bigger than Rotora?
Old Apr 5, 2006 | 12:25 PM
kvon's Avatar
kvon
do you have Work VS-XX though? these wheels have a flatter profile than most others.
Old Apr 12, 2006 | 02:01 PM
ASTIG_Z's Avatar
ASTIG_Z
Mine should be in in about 2-3 weeks...
Old Apr 12, 2006 | 03:11 PM
mbq62's Avatar
mbq62
I NEED HELP ASAP.
Edit/Delete Message
i have a G35 btw
he pretty much knows what he's talking about... my setup clears my brembo's perfectly...
Old Apr 12, 2006 | 03:26 PM
JisNis's Avatar
JisNis
When I was in the market for the VS-XX i was told by one of the vendors that it didnt fit brembos. I chose the Meisters instead.
Old Apr 30, 2006 | 02:12 AM
ASTIG_Z's Avatar
ASTIG_Z
You can special order all WORK wheels for any size, offset and color. Choosing the correct offset will determine if your wheels will clear bremos/BBK.
Old Apr 30, 2006 | 01:40 PM
Zexy's Avatar
Zexy
I NEED HELP ASAP.
Edit/Delete Message
i have a G35 btw
Did you specify you want a low disk or the biggest lip available? It's not about the offset but the disk. That's what determines if your brakes will clear or not. If you have Brembos in the rear you will have to sacrifice additional lip hence a higher disk to clear them.
Calinismo350z
Sep 14, 2015 04:04 PM
Gman2004
Mar 6, 2006 04:40 PM
Gman2004
Mar 1, 2006 05:30 PM
Gman2004
Feb 28, 2006 08:56 PM
