Was buying ADR M-SPORT wheels a mistake?
Old Apr 17, 2006 | 05:33 PM
NM350's Avatar
NM350
I bought H&R 15mm spacers all around and the car looks much better and the wheel wells are filled up nicely now! The only thing is what was mentioned about the vibrations at high speeds!! I need to fix this ASAP because at 130+ you start to slowly feel the vibs....but aesthetically, the spacers make the car look much more agressive in person, IMO...
Im more about the look and feel of the car rather than speed, and the Z for me is already quick enough....maybe down the line I will invest in motor mods but for now I love the look and ride!!
Old Apr 17, 2006 | 07:02 PM
UrbanTacticZ's Avatar
UrbanTacticZ
Your wheels are probably not sitting flush against the rotor thats why you are getting some vibrations.
The centerbore is machined exactly to spec for OEM wheels and sometimes when you add aftermarket wheels, they will not match up correctly. That's where the hubcentric ring come into play to correct the problem and make the wheel sit flush like OEM which in turn reduces vibrations.
It is usually not worth it to buy them online, you can pick them up localy at any tire shop such as Les Schwab or Discount tire and they should be able to assist you with the correct sizes as well. The rubber kind will do just fine for typical applications and will cost around $15-$20 for the set.
However if you are tracking and need some rings that can take some more abuse you may need to pickup aluminum ones and I can help you with pricing on those.
Just shoot me a PM if you are in need of some
Old Apr 17, 2006 | 07:11 PM
NM350's Avatar
NM350
^^ WOW thanks a lot!
I actually have some old ones from my previous car, Imma go check out tomo if they fit! if not you'll be hearing from me, lol!
thanx!
Old Apr 17, 2006 | 07:23 PM
UrbanTacticZ
thanx!
No problem! Motor Tuned is here to serve the community and we hope to be one of the sources that people tap into for help with issues such as these in the future
Old Apr 17, 2006 | 07:29 PM
rich harris's Avatar
rich harris
I had them on my Z for a short time...Z ran just fine with them. my only problem was the offset..they just diden't fill in the fenders well...
Old Apr 17, 2006 | 07:42 PM
reptile718's Avatar
reptile718
I just bought a set of ADR M-SPORT 19" will my TPS sensors fit? Also some of you mentioned rings others spacers, someone hook me up with that I need. I want them to look good not sunken in the car but I also dont want any vibrations. Any help is much appreciated, thanks!
Old Apr 17, 2006 | 07:52 PM
UrbanTacticZ
Send me a PM and I will do my best to assist you!
You can also chat with me on AIM if you want.
My screen name is "MotorTuned" (without the quotes).
I also have MSN and Skype, just click the icons under my username to the left
Old Apr 18, 2006 | 04:50 PM
aznmojo's Avatar
aznmojo
have these on the IS, they are very strong cast wheels, don't worry about it
Old Apr 18, 2006 | 06:58 PM
reptile718's Avatar
reptile718
I bought mine used and the heads of the bolts are pealing, any suggestions on how to fix these, I doubt they are functional and can just be unscrewed.
Old Apr 19, 2006 | 12:07 AM
UrbanTacticZ
Sounds like the previous owner tried to take them apart and realize they were only a 1piece wheel with rivets only for looks
I am not too sure how to "fix" them besides powdercoating the whole wheel again.
Sorry!
Old Apr 19, 2006 | 02:34 AM
reptile718's Avatar
reptile718
Old Apr 19, 2006 | 04:23 AM
teh215's Avatar
teh215
OT: If anyone knows where I can get new center caps for a set of ADR Cyphers, please let me know...
Old Apr 19, 2006 | 03:34 PM
UrbanTacticZ
Call ADR.
www.ADRWheels.com
Old Apr 20, 2006 | 08:55 AM
BMC's Avatar
BMC
Honestly say what you want, but I have these wheels and live in Canada where potholes are HUUUGE and I have yet (knock wood) to bend any! I have hit huge holes and they just absorb the hit! I have BFG tires with 35mm walls and they do just fine
and honestly, the wheels look very good on car!
The only thing is the offset! I had to get spacers after I realized that the wheels just didnt look right (spacers are not in this pic)
NM350,
Very nice ride. That's a really low drop on your car - you say you have hit huge potholes and haven't bent the wheels, but what about the rest of your car? With your car so low I'm surprised you didn't damage or scrape any other part of the underside of your car????
Old Apr 20, 2006 | 09:51 AM
350orevo's Avatar
350orevo
i finally found a pic of these on a redline, and i must say i really like. These are 20s i believe. Now the only decision is to stick with 19s or go with 20s[IMG][/IMG]
Obadabot
Jun 18, 2023 11:31 PM
