can i run 255/45/17 on stock 17s?
Old Apr 22, 2006 | 12:12 PM
guy121's Avatar
guy121
Default can i run 255/45/17 on stock 17s?
I am curious if I can run 255 on the front rims instead of only 245? I know someone on here was running 275 I think on the 18's or 17's but same width rims. will there be a really large buldge? How would it affect the ride/handling if I got them on there?
Old Apr 22, 2006 | 02:22 PM
zachcrosen's Avatar
zachcrosen
From what I had researched, about the largest tires to put on the stock 17s are 245/45 17 up front and 255/45 17 in the back. Go here and play around with tire sizes to see what size wheel they will fit.
http://www.1010tires.com/TireSizeCalculator.asp
Old Apr 23, 2006 | 08:03 PM
What is the OEM tire width . I recommend OEM width + 20mm but no more.
Old Apr 24, 2006 | 02:11 AM
zachcrosen's Avatar
zachcrosen
The fronts are 7.5" and the rears are 8".
Old Apr 24, 2006 | 03:56 AM
Lawn Dart's Avatar
Lawn Dart
Most tire manufactures have a chart for each tire to tell you what width wheel it is compatible with. For example, here is the chart for the Bridgestone RE040.
