RT-615 should i use 255-40-18 or 255-45-18 URGENT!!!
Old Apr 28, 2006 | 11:54 PM
j66's Avatar
j66
Default RT-615 should i use 255-40-18 or 255-45-18 URGENT!!!
hi, i'm going to buy RT-615 tomorrow and i need to know this! i'm going to be using...
FRONT: 245-40-18
but for the rear, i don't know what size is better
Rear: 255-40-18 or 255-45-18
if anyone have any suggestions, please let me know. thank you!
jackie
Old Apr 29, 2006 | 05:25 AM
MustGoFastR's Avatar
MustGoFastR
Do you have VDC? If so, you want to keep the relative sizes between the front and rear tires as close to stock as possible. Stock rear is 2.7% larger in diameter than stock front. With that front, a 40 series rear tire is 1.2% larger and a 45 series is 5.1% larger (a bit larger than stock, so you'll have more mass to rotate and be overdriving the car slightly). I'd go with the 40 in the rear. The best combo actually (what I plan on getting in the same tire) is 235/40-18 in front and 255/40-18 in the rear; that's underdriving slightly for better acceleration and nearly the same ratio front to rear as stock as far as diameter goes withthe rear being 2.5% larger than the front.
Old Apr 29, 2006 | 08:45 AM
j66's Avatar
j66
thanks for you infomation, i'll get the 40 for the rear =)
bigdaddy
Jul 12, 2006 02:43 PM
MustGoFastR
Jun 23, 2006 08:43 PM
dingobiatch
May 5, 2006 04:48 PM
Tekwon-V
Jan 24, 2005 05:33 PM
350z-z33
Jan 24, 2004 03:27 PM
