ADR M-Sport 19" with Tanabe GF210
Old May 11, 2006 | 04:06 PM
Z-Power's Avatar
Z-Power
Default ADR M-Sport 19" with Tanabe GF210
hi
i have m-sport 19inch with 245/40/19 and 275/35/19. do you think GF210 is too low for my car?
thanks
Old May 11, 2006 | 04:32 PM
TanabeUSA's Avatar
TanabeUSA
Smile
Z-Power
The amount that the TGF063 lowers the vehicle is ideal for large diameter wheels. One of the main issues with lowering and large wheel diameters lies in the offset and tire sizing. Aggressive offsets can require the fenders to be rolled on a lowered car.
As long you have a reasonable offset, and are not running plus size sidewall heights or abnormal tire widths, these should install without issue.
If your current wheel+tire setup does not rub your suspension currently, it will not rub with the GF210's.
-Tanabe Racing Development USA
Old May 11, 2006 | 04:36 PM
Z-Power's Avatar
Z-Power
thanks, that means i better not use any spacers tho.
Old May 13, 2006 | 02:23 PM
gimpster621's Avatar
gimpster621
here you go. those were my 1st wheels. im on tanabe gf210's
Old May 13, 2006 | 04:09 PM
Super Avan Z33's Avatar
Super Avan Z33
Hi TanabeUSA need some advice, what should I do with my 2" gap in the rear after I lower my Z's with Tanabe GF210, my wheel/tire size are 18x9 +24 (F) with 255-35-18, 18x10 +24 (R) with 275-35-18, should I just cut the rear spring a bit.
Old May 13, 2006 | 08:49 PM
gsazabi's Avatar
gsazabi
Originally Posted by Z-Power
hi
thanks
You won't have any problem
I have the GF210 with Piaa Super Rozza 19x9 245/35/19(front) and 19x10 275/35/19(rear),
and I have absolutely no problem about the ride height, rubbing issues, etc.
The ride feel is actually more comfortable than the stock springs,
and yet feels firmer. Less body roll, improves handling a bit too.
my offset it +25mm btw.
Old May 16, 2006 | 04:46 PM
TanabeUSA's Avatar
TanabeUSA
In all cases, we never recommend cutting springs. It's not necessarily the cutting that is bad, but it is the heat generated through cutting that can destroy the internal structure of the spring and cause it to snap in the future. Not to mention the fitment issues, or the multitude of other serious and potentially dangerous reasons.
You shouldn't have as large as a 2" gap after lowering with the GF210's. As gimpster showed in his pic, the gap isn't that severe.
-Tanabe USA
Old May 16, 2006 | 08:01 PM
showstoppertk's Avatar
showstoppertk
cutting or heating springs is one of the dumbest things you can do to your suspension.
Old May 17, 2006 | 12:39 AM
Zincognito's Avatar
Zincognito
new guy here and im about to order sf winnings in 19x9.5,10.5 with a +22" offset all around.........i dont want to rub or have to roll any fenders. so how good with these springs be for my car?? thanks in advance
N74DV
Sep 20, 2004 06:04 PM
350 PILOT
Feb 29, 2004 05:15 PM
hmongky3
Jan 13, 2004 10:05 AM
N74DV
Jun 1, 2003 11:32 AM
