Best offset for Volk LE28
Old May 15, 2006 | 11:36 AM
spratocaster's Avatar
spratocaster
Default Best offset for Volk LE28
Hi,
I'm looking to purchase volk LE28N's in 18x8.5(F) and 18x9.5(R). I will be running 245/40/18 tires on the front and 275/40/18 on the rear. What is the best offset for these wheels, keeping in ming I may lower the car and will definitely be tracking it? Thanks.
Old May 15, 2006 | 11:50 AM
ppw350Zunit's Avatar
ppw350Zunit
between +15 and +22.
Old May 15, 2006 | 12:09 PM
spratocaster
+15 seems pretty aggressive for 18's. Will it clear a BBK? Most of the quotes i have gotten have been closer to +30.
Old May 15, 2006 | 11:00 PM
ppw350Zunit
+15 is aggressive but will sit pretty flush with an 8.5 width wheel up front. i wouldn't recommend that offset with an 9.5 width up front though. as for bbk, it all depends on each wheel and spoke design.
Old May 16, 2006 | 03:20 AM
JDMFairlady21's Avatar
JDMFairlady21
if its 8.5 up front you wont go wrong with a +15, it will be flush...
Old May 16, 2006 | 06:44 AM
arizzee's Avatar
arizzee
What type of track will you be running on?
I have LE28Ns with +25 front and +28 rear. This is my street setup. I would recommend those. They clear my oem Brembos and I'm lowered .6" I run 255/40 front and 275/40 rear.
Depending on how much you track (road course), you might consider running 9.5" +28 on all corners. You can run 275/35 fr and 275/40 rear or 275/35 on all. That's my track setup (but I run 9.5'" +30 LMGT4s) w/ Falken RT-615s.
Old May 16, 2006 | 07:22 AM
spratocaster
I will be running mostly autox with a couple track days thrown in. I have found a pretty good deal on 8.5 +30 (F) and 9.5 +28 (R). How would this setup work for the track?
Old May 16, 2006 | 10:28 AM
arizzee's Avatar
arizzee
Those should be fine. might want to check Rays' website for their sizing charts http://rayswheels.co.jp/indexe.html just to get an idea what they say will fit.
Old May 16, 2006 | 11:06 AM
spratocaster
According to Rays, those offsets should clear the stock brembo's. I have a performance model, so it will definitely fit now. I am just curious if it will clear a bbk in the future.
Old May 16, 2006 | 12:48 PM
plastiketa's Avatar
plastiketa
A bit off topic:
Why run 9.5 all around for track? Is this a better setup then 8.5F/9.5R? Or is this more of a "More tire on the ground" concept?
Old May 16, 2006 | 01:29 PM
ppw350Zunit
Originally Posted by plastiketa
A bit off topic:
to reduce understeer??
Old Sep 18, 2006 | 07:24 PM
Amiricanmade's Avatar
Amiricanmade
OFF TOPIC:
so no 2 12offset on a 19x9.5/10.5 wheel?
Old Sep 18, 2006 | 08:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
might want to first make sure they will even make the wheels as LE's were discontinued
Old Sep 19, 2006 | 07:01 PM
Volk350Z's Avatar
Volk350Z
Master
Rays don't offer +15 for 18x8.5 CE28N
recommanded size for that width is +25 & +22
This will also clear BBK or OEM brembo..
Stevo Z
Oct 3, 2015 09:14 PM
