::NISMO Wheels Thread::
Old Aug 15, 2010 | 01:31 PM
  #901
Waiz's Avatar
Waiz
Originally Posted by 350zGatorman
Cool, I checked out your pics but it's so hard to tell with a black car when looking on a computer screen. I'll try to find some pics of the silver, yellow, white Z's and see but I'm definitely leaning towards the pro kit.
Sounds good, this may help out as well:
https://my350z.com/forum/brakes-and-...re-thread.html
Old Aug 15, 2010 | 01:48 PM
  #902
370zGatorman's Avatar
370zGatorman
Thanks for the link. Checking it out now...
Old Aug 15, 2010 | 02:06 PM
  #903
kham25's Avatar
kham25
Old Aug 15, 2010 | 02:10 PM
  #904
370zGatorman
Thanks for the pic. I'm still looking at that thread but so far I'm sold on the ProKit. I'm checking to see if I need to roll fenders, 20mm front and 25mm back spacers, camber kit, etc. It would be nice if I could just throw the springs and spacers on and get an alignment lol
Old Aug 15, 2010 | 02:30 PM
  #905
Ruthless18x's Avatar
Ruthless18x
I'm back from Bama I know, I'm trying to decide on springs and spacers so I can get it lowered. It's still dirty as it was pouring rain all through Bama and Georgia.
Looks great man!
Old Aug 15, 2010 | 02:42 PM
  #906
VQpoweredZ's Avatar
VQpoweredZ
Just roll the rear fenders anyway. It's so nice just getting it out of the way and not thinking about it 24/7. I used to be against it, but it wasn't that bad getting it done by someone who knows what they are doing. Shouldn't be more than 80 bucks for both rears to be done.
Old Aug 15, 2010 | 02:43 PM
  #907
370zGatorman
Good advice and I'm taking it for sure.
Old Aug 15, 2010 | 05:07 PM
  #908
AadosX's Avatar
AadosX
Yup what these guys said. Just go ahead and roll the fenders. If you want to use spacers at all (which I highly suggest), you'll need to roll the fenders.
And if you're still on the fence about which springs to get, I have pics of my car on Pro-Kits I think. ;-) With Pro-Kits you should be able to get away with 20mm front 25mm rear no problem.. just roll the rear fenders.
Old Aug 16, 2010 | 09:14 AM
  #909
Gingervitis526's Avatar
Gingervitis526
How much of a drop did those springs give you?
EDIT: Just looked them up, 1" front and rear...
Old Aug 16, 2010 | 10:42 AM
  #910
370zGatorman
Thanks Aadosx, getting dropped with the ProKit on saturday and I should have your TPMS out today or tomorrow. The pic of your Z with the Pro Kit is in that thread that was linked to above.
Old Aug 16, 2010 | 01:33 PM
  #911
AadosX's Avatar
AadosX
Awesome! You'll love the springs. Honestly on Pro-Kit I think I would probably just go get an alignment and not bother with the camber kits. Just tell them to set your toe to zero all the way around, or maybe 1/32 inch in the rear for a little bit of help exiting the corners. Then just tell them to get the camber as close to 0 in the rear as they can... the front camber is not adjustable with factory parts but it will be a non-issue with 0 toe. Just remember, camber alone doesn't really kill the tires, but camber combined with toe does. What stinks about our cars in the rear is that as you dial out toe, it dials in camber. and vise versa. blah!
EDIT: Signature updated. =*(
Old Aug 16, 2010 | 01:57 PM
  #912
angelo350z's Avatar
angelo350z
^^ What he said. Toe is what really eats up tires. I drove 200 miles to Frankfurt with 80% tread on my tires (not on the Z33), and by the time I got back, the outside of the tires were literally bald. I couldn't tell because the car didn't pull in any direction at all, and I just purchased it after passing German vehicle inspection.
Old Aug 16, 2010 | 02:15 PM
  #913
370zGatorman
Thanks very much, will copy that post to show the alignment place! I can't wait to see it dropped and will do the spacers in a few weeks.
Here's the current plan per the install shop. Install the Eibach Pro Kit this saturday with an alignment soon afterward. Then get the spacers and install those a little later and finally roll the fenders. They stated putting the spacers on later will not affect the alignment.
And an FYI for those considering springs. It was AadosX's Z that had the LMGT4's. When I bought them from him we replaced his LMGT4's with my stock 17's wheels. His car STILL looked as good as mine because he was dropped with spacers. It's amazing how much the springs and spacers change the appearance of a car!
Old Aug 16, 2010 | 04:19 PM
  #914
Ruthless18x
Do work son. It'll look good.
Old Aug 16, 2010 | 07:43 PM
  #915
JjL's Avatar
JjL
I would go with coils cause I get more adjustablity and feels like its on rails while turning.
I'm on bc racing coils. not sure how much I dropped but I do rub very slighty on bumps on my front pass side so gotta raise it up 1 cm.
And yes fix your toe if you don't want to eat up your tires. when I used to drift I went through a brand new pair of federals in 8 laps cause I had some toe. too much camber also wears the tires out fast also so i'm pretty much use to tires lasting one season lol.
Old Aug 17, 2010 | 08:58 AM
  #916
AadosX's Avatar
AadosX
Sounds good. Just tell them that when they adjust your toe it will throw off the camber, and vise versa. A lot of alignment guys are lazy, and they won't realize this at first just from looking at the car. So they will adjust the camber, then adjust the toe.. and be like "well when I adjusted your toe your camber went off" without re-adjusting the camber again. In other words.. they have to kind of play with it to get it just right. But again, what you want is
0 toe up front.
0 or 1/32" toe rear.
Whatever camber it is up front (it's not adjustable).
And I would just get as little camber in the rear as you can, or match it to what the front camber spec is
I would guess that you will have about 1.5 or 2 degrees of camber up front after the drop.
Right now I'm rocking 2 degrees of camber front and rear, 0 toe up front and 1/32 rear. The car handles very well!
And you are correct, installing spacers won't affect the alignment. You can install the spacers yourself, it's just like putting on wheels. I also suggest waiting at least 2 weeks after spring installation before getting an alignment as they typically seem to "settle in" which lowers the car just a tad more.
Old Aug 17, 2010 | 10:52 AM
  #917
Gingervitis526
Good info in here, thanks AadosX
Old Aug 19, 2010 | 08:53 AM
  #918
370zGatorman
Checking on spacers and wanted to be sure. Do I need the Ichiba v2 spacers with lmgt4's? I searched and couldn't find the exact spacers people were using with these. I think I'm going with the Ichiba V2's unless there's something better. thanks!
Old Aug 19, 2010 | 11:21 AM
  #919
AadosX's Avatar
AadosX
Those are fine. Those are like the ones I have. They bolt onto the car. The V1 style require putting new wheel studs in.. and are only necessary if you plan on tracking the car hard and often... in which case I wouldn't recommend spacers anyways really. =P
I have H&R because I prefer their brand name quality. There are also Eibach spacers. Both of these cost more though. Ichibas will be fine, everyone here seems to use them without any issues.
Old Aug 19, 2010 | 11:23 AM
  #920
370zGatorman
Sounds good, thanks!
