tire pressure?
Old May 24, 2006 | 11:25 PM
The Law's Avatar
The Law
Default tire pressure?
what is the tire pressure for the 18" oem rims? im asking this because i just bought the track rims for my maxima and need to know how much air the tire needs to be at. thanks
The Law
Old May 24, 2006 | 11:31 PM
heezyo2o's Avatar
heezyo2o
recommended 35psi cold, but it doesn't hurt to go a little lower than that.
Old May 24, 2006 | 11:33 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Hot Weather = 30-35psi cold
Cold Weather = 35-40psi cold
Note: As you warm up your tires, your psi wheel increase.
But 35psi is recommended by your manual.
BTW...don't mean to sound like an a** but this has been discussed before so I'd do a search before you post.
Old May 24, 2006 | 11:44 PM
Ruth's Avatar
Ruth
Look in your glove box,Check out CarBibles.com
Old May 25, 2006 | 01:01 AM
The Law's Avatar
The Law
if you knew how to read you would have seen my post where i said i drive a MAXIMA...i didnt say i drive a 350z
GTNPUZ - hey did you go to freakmont? cause i see you live in the bay. im jw cause i was there as im part of Team Driven which was one of the 2 host that were there
Old May 25, 2006 | 06:25 AM
Then maybe the question is best suited for a Maxima forum.
Old May 25, 2006 | 06:28 AM
Swiffer's Avatar
Swiffer
Tire pressure is not determined by the wheel. It is based on the vehicle and the tire itself. A 350z owner is not going to know what is required for your Maxima.
Old May 25, 2006 | 08:18 AM
kelementz's Avatar
kelementz
but he has the 350z track wheels on his Maxima....
Old May 25, 2006 | 09:18 AM
VO...'s Avatar
VO...
Administrator
35/cold all the way around.
Old May 25, 2006 | 10:02 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Yep. I was there.
BTW...I believe the Maxima uses roughly the same psi so if you stay within the same range, I think you'll be okay. I have a friend who has a Maxima & runs it between 35-38psi.
Old May 25, 2006 | 10:06 AM
Swiffer's Avatar
Swiffer
So? That doesnt mean anything.
Old May 25, 2006 | 11:32 AM
Ruth's Avatar
Ruth
Dear Dick(the law) , Does a Maxima have a glovebox?
Old May 28, 2006 | 01:45 PM
Ruth's Avatar
Ruth
The home page says 350Z---not MAXI(pad)MA. YOU READ!
Old May 31, 2006 | 08:51 PM
raceit's Avatar
raceit
First of all, you don't put psi into RIMS.
I'm surprised you didn't take into account the weight of the maxima when using any tires. The weight of the maxima versus the 350z is going to have different effects on the tire and psi. Other than that, why put 350z wheels on your maxima? Personal choice of course, more power to you. Have at it...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
