20 inchers I need some help
Old Jun 5, 2006 | 06:02 AM
hater's Avatar
hater
Default 20 inchers I need some help
Those of you guys rockin 20 inches what size tires are you running? I have done some searching and it seems to vary, I've seen people having trouble running 255/35 and 285/30. What works for you? What doesn't rub with a slight drop?
I really like the Axis Matrix 20x9 and 20 x 10.5, just not sure what rubber to look at. Any help would be greatly appreciated.
Old Jun 5, 2006 | 08:57 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
255/285 will work even if you drop more than 1".
Matrix is nice. Deep lip. Good choice.
Check under Discount Tire Direct, they have the combo for around $2250 or $2300 (tire and wheel). BTW, don't get Toyo tire. BGF better.
Old Jun 5, 2006 | 09:20 AM
sobceo's Avatar
sobceo
I just ordered my tires.. I got 245/35 and 275/30.. Does anybody have that size with a 1" drop??
Old Jun 5, 2006 | 10:46 AM
hater's Avatar
hater
Thanks for the reply guys. Any VCD issues with 255/ 285?
Old Jun 5, 2006 | 02:36 PM
chicklet's Avatar
chicklet
Originally Posted by Bubble
255/285 will work even if you drop more than 1". BTW, don't get Toyo tire. BGF better.
Agreed! BFG KDW2 all the way!
I didn't have any issues with the VDC...I have more issues with the stock 17s than I did with the 20s. You know you can always install the KPTech VDC module...NO MORE VDC!
I had the 255/285 setup with 30 profile (8.5 front and 10 rear). No issues for me in my G coupe (I did not have a drop though). If you are ever weary, just roll the fenders.
Old Jun 5, 2006 | 02:38 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
+1
I'm running 20x9 + 20x10 with 255/285.
Old Jun 5, 2006 | 03:25 PM
350ztoronto's Avatar
350ztoronto
you'll be fine i have tanabe nf210 im much lower then 1 inch
Old Jun 5, 2006 | 09:46 PM
glogan's Avatar
glogan
Default 245/35 and 275/30
call em back, I had the same set-up and did not like the set-up one bit. Either go with 285/30 or 275/35 for the rear...
Old Jun 5, 2006 | 10:05 PM
sobceo's Avatar
sobceo
I am not good on tire size.. But what would that tire size difference make for the rear??
Old Jun 6, 2006 | 11:24 AM
hater's Avatar
hater
How about this for tire sizes?
245/35R-20 Front
275/35R-20 Rear
For 20x 9 and 20 x 10.5
Old Jun 6, 2006 | 01:28 PM
glogan's Avatar
glogan
Default tires
More tire, less gap, less dings on your rims, looks better
Old Jun 8, 2006 | 11:17 AM
Gilley's Avatar
Gilley
245/35R-20 Front
275/35R-20 Rear
Those tires will be very stretched.
I have Nitto 555's on Maya GR5 20x9 front on 255/35 and 20x10.5 rear on 285/30 and my rear tire is stretched too much for me.
I'm looking for some 295's or at least 285/35's.
Attached Thumbnails 20 inchers I need some help-left-rear-and-side.jpg   20 inchers I need some help-headlight-shot.jpg   20 inchers I need some help-rear-wheel-angle.jpg   20 inchers I need some help-left-rear-three-quarters.jpg   20 inchers I need some help-right-rear-3.jpg
Old Jun 8, 2006 | 11:22 AM
sobceo's Avatar
sobceo
What do you mean "stretched"? Before I bought my tires I asked specifially on this board what size to get.. smh.. I havent mounted my tires to my new rims yet.. But I will have to make do with them either way now.. As long as there low profile and fit I will be happy.. If there is a gap I will just lower the car like I planned to anyway..
Old Jun 8, 2006 | 11:44 AM
Gilley's Avatar
Gilley
Stretched is when the rim is wider then the tire and the tire's sidewall isn't vertical. It leaves your lip vulnerable for curbing.
Old Jun 8, 2006 | 11:55 AM
sobceo's Avatar
sobceo
Oh I see what your saying.. But seems like if its not "stretched" look, then you would get the "bubble" look. Where the tire bubbles out over the rim. I want the squared look. Not sure if this makes a difference...
So i guess the best thing would be for the rim and tire tire to be edge to edge straight..
Old Jun 8, 2006 | 12:00 PM
hater's Avatar
hater
Perfect, I want a stretched tire. I think Axis Matrix with these tire sizes will look sick! Well I hope so anyways.
Old Jun 8, 2006 | 12:02 PM
Gilley's Avatar
Gilley
Right.
I want the squared look too.
Old Jun 8, 2006 | 12:03 PM
CAVZ33's Avatar
CAVZ33
I was running 255/35 285/30 on 20x8.5 and 20x10 and had some problems with my TCS. My Z would cut out gas and I was like a sitting duck in the middle of the freeway . So I went with 245/35 275/35 that fixed the problem but It kind of gave me the streched look in the rear. So if you go with 275/35 with 10.5 its going to look real streched-IMO.
joust75
Feb 29, 2004 03:54 PM
