Rear shimmy under hard braking (high speeds)
Old Jun 8, 2006 | 08:28 PM
rodH's Avatar
rodH
Default Rear shimmy under hard braking (high speeds)
I got this before on my stock rear rotors and it never went away after I applied the brakes going down a long hill high after traveling 120ish. I guess it laid brake material down and caused this. I put on a set of Stillen drilled/sloted rotors and did a similar thing tonight and it shimmied/shook again, but not after than initial brake (ie-it is fine now). Why does my car do this, NO shacking with normal braking, or driving at ANY speed. Is it because the load is just to high with BIG Tire/wheels, going down hill, braking from such a high speed????
THOUGHTS???
Old Jun 9, 2006 | 08:11 AM
Q45tech's Avatar
Q45tech
Measure the rotor [indexing] axial and radial runout per FSM............as the rotors heat up they can go out of spec...............0.0028" MAX.
Old Jun 9, 2006 | 08:16 AM
rodH's Avatar
rodH
how the hell do I measure that??
Old Jun 9, 2006 | 09:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
With a tool you dont have
Old Jun 9, 2006 | 09:09 AM
disturbed2483's Avatar
disturbed2483
^^^lol
Old Jun 9, 2006 | 09:11 AM
rodH's Avatar
rodH
and the knowledge I don't have either
Seriously, is this a common problem??
Old Jun 9, 2006 | 09:17 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Im starting to think its a common tendency for some Z's to feel loose in the rear when braking hard. I have this issue with my JIC coilovers, though I dont remember it happening stock. Ive read of many people asking about it. In all honesty if your decent on your brakes the rotors being warped likely isnt an issue, but if you bought some cheap a$$ rotors then maybe. While warped rotors can lead to this feeling, I dont think its the issue in your case.
Old Jun 10, 2006 | 06:52 AM
Kolia's Avatar
Kolia
Sounds like a rear toe issue.
hulkout
Apr 28, 2017 09:00 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
