What wheel spacer do I need? Do I even need them?
Old Jun 12, 2006 | 05:13 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Default What wheel spacer do I need? Do I even need them?
I bought my volks from 350zforums last year and they came out great IMO. However, the offset of my front rims were a little different from what people normally run here.
The rears are 9.5 +22
The fronts are 8.5 +29
Here are some pictures of them on my car:
This is before I put my tein S tech springs on
After the Tein springs:
Do I need a spacer in the front? Or do you think it looks fine as it is?
Old Jun 12, 2006 | 10:31 AM
ichibausa's Avatar
ichibausa
Can you measure the gap between the front tire and the fender?
The rear looks fine from your pic. If you can get closer pic on front and the back, I may figure out for you.
Old Jun 12, 2006 | 11:17 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I would assume from the top of the front tire to the inner lip of the fender?
I think the rear looks fine its just the fronts I am worried about.
Thanks for helping me.
Old Jun 12, 2006 | 01:56 PM
ichibausa's Avatar
ichibausa
Yes, measure the top of the front tire to the inner lip of the fender. Always!
Old Jun 12, 2006 | 02:27 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
it is right at 1 inch from the rubber to the lip I think. do you think a 25 mm spacer would be just right?
Old Jun 12, 2006 | 02:28 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
double post
Old Jun 12, 2006 | 02:44 PM
VenomZ's Avatar
VenomZ
I have a 2 brand new 25 mm hub centric adapters that would fit perfectly on your fronts. They are brand new and will sell them for $120 shipped.
Old Jun 12, 2006 | 02:45 PM
baileyrx's Avatar
baileyrx
i'm thinking 15mm in the front
the rear looks good
Old Jun 12, 2006 | 02:46 PM
3FITTTY's Avatar
3FITTTY
15 max!
Old Jun 12, 2006 | 02:59 PM
VenomZ's Avatar
VenomZ
15 millimeters = 0.590551181 inches
if you want them to sit flush...you wont listen to those that tell you 15 mm is what you want
Old Jun 12, 2006 | 04:06 PM
RNL323's Avatar
RNL323
Mod My Ride
Your rear is fine...
I would get a 5mm spacer for the front so you will be +24. I believe with a 5mm you can still use your stock bolts.
if you went with 15mm as someone mentioned above you'd be at a +14 offset which wouldn't work at all...your wheels would be outside the fender LOL.
Old Jun 12, 2006 | 08:40 PM
superppwZ33's Avatar
superppwZ33
yup +14 would be too low
there are a few z's that run offset that low or even lower
but with cut/rolled fenders
so with stock set up ideally you wanna stay around 20 or up in the front
and you can run 245/35/19 or 255/35/19 tires
and yes 29 does look quite a bit sunken in
Old Jun 13, 2006 | 01:01 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I ended up going with a 10mm spacer. Eibach hubcentric
I will post results
Obadabot
Jun 18, 2023 11:31 PM
