Punctured Tire Repair?
Old Jun 13, 2006 | 08:28 AM
JSON's Avatar
JSON
Default Punctured Tire Repair?
So it seems that a nail punctured through my tires and air has been leaking slowly (not a Z). I just noticed it today and filled it up again but now I'm worried about how to fix it. I'm reading that plug-in-repair methods are improper and will cause further damage. Is this really something I need to worry about? Do I need to take it to a wheel/tire shop and have them take off the tire and properly fix it? Also, around how much would that cost? BTW, the car is a 03 Accord Coupe and the tires are Yokohama 205/65/15. The tires were bought around 6 months ago and still have a lot of tread on them.
Thanks
Old Jun 13, 2006 | 08:37 AM
VO...'s Avatar
VO...
Administrator
If you can take it to where you bought the tires, they might fix em' free. Discount tire fixes flats for free. NTB does it for about $20.00.
A plug is a temp fix. The correct/permanent way to fix a puncture is to patch it.
Old Jun 13, 2006 | 08:38 AM
JSON's Avatar
JSON
I bought it from my cousin who works at a Toyota dealership for a cheaper price...so they probably won't help.
I'll see if there's a Discount Tire around here. Thanks
Old Jun 13, 2006 | 08:39 AM
dubbzdiggler's Avatar
dubbzdiggler
get the continental ContiComfort Kit...it's a air compressor and it also has a latex based, water soluable sealant if you totally lose all of your air....it's like the size of a lunch box and it is what comes iwth the Z06 and Ford Gt
Old Jun 13, 2006 | 08:48 AM
JSON's Avatar
JSON
I already went to BP and put some air in it. I'm just looking to get it permanently repaired now... DTD is around 8 mi from my house and NTB is around 7. I don't know which one would be a better place to go to.
Old Jun 13, 2006 | 09:03 AM
JSON's Avatar
JSON
Ok, free repair at DTD vs. $23 at NTB.
Hmm hard decision.
Also, do you think I can drive 8 miles on the tire or should I put to spare on it....I don't feel like lifting the car today
Old Jun 13, 2006 | 09:08 AM
Take the tire to a competent shop. Generally, holes in the tread can be repaired. Sidewall damage can not.
Old Jun 13, 2006 | 09:22 AM
JSON's Avatar
JSON
Yeah, luckily it's directly in the middle. I'm going to set up an appointment with DTD today.
Old Jun 13, 2006 | 09:42 AM
VO...'s Avatar
VO...
Administrator
Hmm hard decision.
slow leaks where the object is still embedded are ok to drive. Do not go fast though. I once did this and have the bolt, that had punctured my tire, actually dislodge while I drove at about 85mph. I ended up having to change the tire on the emergency lane.
Old Jun 13, 2006 | 09:49 AM
JSON's Avatar
JSON
Haha, I'll try to go under 60mph since I have to go thru a large road. Thanks for the response
Old Jun 13, 2006 | 09:53 AM
VIPLINE's Avatar
VIPLINE
A tire shop can dismount the tire & patch it form inside. This is the best & safest way to repair a tire.
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
