offset
Old Feb 17, 2003 | 04:51 PM
SUPERMAN350Z's Avatar
SUPERMAN350Z
Thumbs up offset
Im ready to order the axis rim:19 x 8: 2.25 inch lip in the front and 19 x 9 in the rear 3 inch lip. what do guys think will be the best offset for the rims.
Old Feb 17, 2003 | 04:56 PM
Stone Z's Avatar
Stone Z
22f/27r
Old Feb 17, 2003 | 05:12 PM
SUPERMAN350Z
how did u come up with those #?
Old Feb 17, 2003 | 05:16 PM
Stone Z's Avatar
Stone Z
Lightbulb
Try using the search function for offsets....this subject has been covered *extensively*.
Old Feb 17, 2003 | 06:33 PM
rodH's Avatar
rodH
F=+20mm
R=+20mm
fairly agressive, that is approx what you will see on Skidazzles VOLK GT-C
Old Feb 18, 2003 | 04:52 AM
j's350z's Avatar
j's350z
Axis only makes 35mm offsets, unless you are getting the 3 peice seven's, and if you are , i would reccomend something else for 4k.
Old Feb 18, 2003 | 09:54 AM
MATIX's Avatar
MATIX
Originally posted by rodH
F=+20mm
R=+20mm
skidazzles gt-c's are +27 front, +24 rear...so are mine
Old Feb 18, 2003 | 01:11 PM
rodH's Avatar
rodH
yep, BUT you are also running a 8.5 front and 9,5 rear NOT 8 and 9"
that is why the offsets are different.
Old Feb 18, 2003 | 01:15 PM
OMEGATLC's Avatar
OMEGATLC
Default Axis Whees
If you're getting the Axis Se7en Mods, check out the wheel and tire group buy in the classified forum. You will need to email them for the pricing, if you haven't received it already.
The Axis Seven Mods come in a 35mm or 47mm offset, but most 350Z are going with the 35mm with a 20mm spacer up front and the 35mm in the rear. This is for a 19" front/20" rear combo. Definitely check them before you order. "bdiddy" has this set up on his black Z. Try a search in the Wheel and tire forum for pics.
Old Feb 18, 2003 | 01:26 PM
HREWheelMaker's Avatar
HREWheelMaker
MATIX, you can't fairly compare the same offsets (among different wheel widths) if you are looking at how they look related to the fender. Offset is the distance from the imaginary centerline of the wheel to the mounting surface. For example, a 19x8.5+24 sits 1/4" more outboard than a 19x8 +24.
It's complicated, that's why guys like me get the big bucks!
Personally, I'd go 19x8 +11 and 19x9 +11 if I was going that narrow- This would sit the same (relative to the fender) as our LeMans Sunset SEMA car. If you're concerned about scrub radius, use something closer to the OE offset, around +30. The wheels will look "tucked in," like the OE wheels.
The 3-piece Axis is a terrific wheel...
Old Feb 18, 2003 | 01:31 PM
SUPERMAN350Z
I called axis this morning and they said there yellow axis car has a 32mm offset in the front with a19x8.5 and in the rear 47mm with 19x10.5 . do these figuers sound right to u guys?
they also said all the wheels are custome made
Old Feb 18, 2003 | 01:44 PM
HREWheelMaker
Both of those offsets are more inboard than we run them, but they will work.
The rear 19x10.5 +47 will rub on the inside plastic "fender liner" when the car is jacked up. I'd prefer to run the 10.5 down in the low 30mm offset range. If you want an aggressive look, you could use a spacer to get there...
If I had a 350Z, I'd roll the crap out of the rear fenders and go 19x10.5 +16.
Old Feb 18, 2003 | 02:04 PM
MATIX's Avatar
MATIX
I wasnt trying to compare the offsets, i was simply stating the correct offset that skidazzleand myself are running for the wheels we have.
Old Feb 18, 2003 | 02:20 PM
rodH's Avatar
rodH
they are referring to the $1500/wheel model.
btw, here is a site that converts offsets
http://toy4two.home.mindspring.com/offset.html
Old Feb 18, 2003 | 02:50 PM
SUPERMAN350Z
DO U HAVE ANY PICS OF UR RIDE ON THE RIMS MATIX?
Old Feb 18, 2003 | 02:55 PM
MATIX's Avatar
MATIX
I'm pickin up the tires for em on thursday, so once i get em mounted and balanced, i'll post some pic
Old Feb 18, 2003 | 03:47 PM
rodH's Avatar
rodH
where did you buy them???
Old Feb 18, 2003 | 05:05 PM
MATIX's Avatar
MATIX
Proto motorsports in Riverside
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
