18x9 all around ok?
Old Feb 19, 2003 | 04:13 PM
redlineRED350z's Avatar
redlineRED350z
Default 18x9 all around ok?
Ok i am thinking of running 18x9 all around. What do all of you think? and what tire size should i have? Thanks
Old Feb 19, 2003 | 06:25 PM
2003z's Avatar
2003z
should be good, my rear 18x9s fit fine in front, just can't use the stock 225s with them.
Old Feb 20, 2003 | 04:59 PM
redlineRED350z
2003z, soi what size tires do you use for the front and rear?
Old Feb 21, 2003 | 08:26 AM
Pedal Pusher's Avatar
Pedal Pusher
Check on Tirerack.com for tire sizes for the 9" rims. You will probably find a tire that will be about the same diameter as the stock tires. Look at 245/45 and 255/40. I would suggest you not go over 255's on the front. It will cause the car to wonder on uneven pavement.
Old Feb 21, 2003 | 11:19 AM
droideka's Avatar
droideka
A 255/40/18 in a S-03 is 26.1" in dia., a mere .1" bigger than the stock 225/45/18. In other words, it should be just fine if it doesn't rub on extreme turns.
Old Feb 21, 2003 | 12:37 PM
2003z's Avatar
2003z
I'm currently running stock tires on 18x8 and 18x9. I would have gone 18x9 all around if I was going to replace all the tires then too. Tire Rack told me 255 was too aggressive for the front. I think 245/40 265/40 combo would work well.
As for the above post about the rears fitting the front, I put them on there to check clearance for a wider tire. with the 18x9 +30, there wasn't much room for anything bigger than a 245. Had prob. about 1/8" clearance with the upper control arm.
Old Feb 21, 2003 | 01:37 PM
droideka's Avatar
droideka
I assume that the clearance issue was top to bottom and not side to side, right? That 245/45/18 you put on the front had an overall diameter of 26.7" while a 255/40/18 is 26.1". Do you think it would have cleared had the diameter not been 26.7"?
Old Feb 21, 2003 | 03:28 PM
2003z's Avatar
2003z
yes, a smaller diameter would have given a little additional room and would probably clear, since the a arm curves outward.
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
nissan_fanatic
Oct 5, 2004 11:43 AM
BOZ23
Sep 8, 2004 11:46 AM
350ZRB
Apr 13, 2004 11:14 AM
