Le28n mounting issue
Old Jun 30, 2006 | 06:48 PM
Changvi's Avatar
Changvi
Default Le28n mounting issue
just purchased a set of used Le28n for 350z from a member on this site. When I try to mount the wheels to the car, it does not slide all the way in. So i looked at the stud, it appeared that the bolt that secures the rotor to the front bearing is in the way. So what can i do to make it work. I'm also having slotted rotor and new brakes installed tomorrow. Do you think it would help? any input would be appreciated.
Old Jun 30, 2006 | 06:55 PM
kuo246's Avatar
kuo246
any pics?
Old Jun 30, 2006 | 06:57 PM
DavesZ#3's Avatar
DavesZ#3
Remove the bolt. It's something the factory puts on to prevent you from accidently mounting the rear wheels on the front of the car. Aftermarket wheels don't have the little hole in the back of them that the stock wheels have.
Old Jun 30, 2006 | 06:59 PM
Changvi's Avatar
Changvi
no, but i was just looking at 350z DVD.....i think these wheels were made for z's with Brembo braking system. Brembo does not have the extra bolt that secures the rotor to the bearing. Non brembo has an extra bolt extruding from the rotor...damn..... Do you think by replacing the rotors would help?
Old Jun 30, 2006 | 07:02 PM
Changvi's Avatar
Changvi
oh, ok. Just by simply removing the bolt will allow the wheels to slide in. How about the rotors? would the rotors stay in place? I thought it had something to do with the type of braking system.
Old Jun 30, 2006 | 07:11 PM
LvntheZ's Avatar
LvntheZ
nope just remove the bolt i had same problem for like 1 min and then i said f- it and took it off....
Old Jun 30, 2006 | 07:19 PM
Changvi's Avatar
Changvi
Thank you very much for your input DavesZ#3 and Ivnthez. Never thought installing aftermarket wheels could be pain in the ***. I will have my shop to remove the bolt tomorrow. Thanks again...
Old Jun 30, 2006 | 07:21 PM
Volk350Z's Avatar
Volk350Z
Master
Changvi.. hope you got the wheels on.. call me if you have any problem.. take some pix..
Old Jun 30, 2006 | 07:30 PM
Changvi's Avatar
Changvi
I will have my wheels on tomorrow. Just need to remove the bolts on both front bolts. Thanks again for your fast response. Wheels look great!
Old Jun 30, 2006 | 07:35 PM
Changvi's Avatar
Changvi
here is a quick snap shot of the wheels.
http://pg.photos.yahoo.com/ph/thisaz.../ph//my_photos
Old Jul 1, 2006 | 08:49 AM
NISMOFO's Avatar
NISMOFO
Those wheels look awesome. If you have a friend, they can sit in the car and hold the brake pedal down while you take the bolt out so the rotor doesn't turn. Otherwise, there is another trick to doing it by yourself but it's kind of ghetto.
Old Jul 1, 2006 | 06:43 PM
Changvi's Avatar
Changvi
Brian..These wheels look awsome. Just had them mounted. I will have pics up soon..thanks again...
Old Jul 1, 2006 | 07:43 PM
Volk350Z's Avatar
Volk350Z
Master
cool.. good to hear..
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
