Put H&R Spacers and Hubcentric rings - vibs near 130km/h and higher!
Old Jul 6, 2006 | 06:04 PM
NM350's Avatar
NM350
Default Put H&R Spacers and Hubcentric rings - vibs near 130km/h and higher!
Any solution to this problem? I was told that putting hubcentrics would make the problem much less noticable but about 2 days after I put them on, I got the vibs again!
I was warned that this is a common consequence when adding spacers, but I was wondering if anyone had a fast and easy result without getting new wheels with the correct offset
Your help is appreciated in advance!
Thanks
Note: the spacers are 15mm all around and my wheels are ADR M-Sports +35
Old Jul 6, 2006 | 07:32 PM
MustGoFastR's Avatar
MustGoFastR
Well, if they ar H&R spacers, then they are already hubcentric, so not sure what you're trying to accomplish by putting hubcentric rings on; or am I misunderstanding something? The H&R spacers should not produce any vibration. I suggest taking them off and seeing if the problem persists. If so, you may just need your tires balanced.
Old Jul 6, 2006 | 11:15 PM
roncfpz's Avatar
roncfpz
Agreed, H&R are hubcentric spacers and should not produce any vibration. Also, consider re-torquing the bolts to make sure the wheels are seated properly.
Old Jul 7, 2006 | 05:59 AM
Chad68's Avatar
Chad68
Thanks
I have 15mm H&R spacers on the rear of my stock 2006 18" wheels and no spacers on the fronts.
I have had it up to 130 MPH with no vibrations.
Did you have the car up to those speeds before you installed them?
Old Jul 7, 2006 | 06:00 AM
Chad68's Avatar
Chad68
His wheels require hub rings with or without using the spacers.
Old Jul 7, 2006 | 08:50 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
H&R Spacers are hub centric for the NISSAN OEM Hubs and NISSAN OEM Wheels.
I dont know of any Aftermarket wheel that has the same center bore size like the 350Z besides the NISMO LMGT4's...
99.999999% of aftermarket wheels have larger bore sizes so they will fit on other vehicles that have the same bolt pattern but a lager bore diameter...
Bore Size:
NISSAN 350Z / G35: 66.2
ACURA RSX for example: 64.1
I dont know the bore size of the ADR wheels, but you will need a hub ring for it...
What kind of hubrings did you get? Plastic or Aluminum?
Old Jul 7, 2006 | 08:52 AM
sq40's Avatar
sq40
I had the same problem and it was due to a lug nut issue. Have you changed nuts? Are you sure you are torqued Properly? The H&R Studs are very soft and can easily be threaded.
Old Jul 7, 2006 | 08:54 AM
sq40's Avatar
sq40
Read these two Threads;
https://my350z.com/forum/showthread....26amp%3BR+Stud
https://my350z.com/forum/showthread....ight=Vibration
Old Jul 7, 2006 | 08:59 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
i got em all the way around and havent had any problems???
Old Jul 7, 2006 | 04:47 PM
NM350's Avatar
NM350
Thanx for the Help so far guys!
I purchased plastic hubcentrics!
I'm going to inquire about lugs and torquing the lugs properly
Old Jul 7, 2006 | 05:06 PM
sq40's Avatar
sq40
See if you can get Aluminum ones, the Plastic stuff seems to distort over time.
If you don't have one, I suggest purchasing a Torque Wrench, 5" Extension and a Deepwell Socket that fits your Lugs. All can be had for less than $50.
Old Jul 8, 2006 | 01:11 PM
Q45tech's Avatar
Q45tech
Hopefully you have measured the radial force imbalance of the tires mounted on wheels and they are below 11 pounds..............For high speeds: 5 pounds is a better number at the 3rd harmonic 120-130 mph.
http://www.gsp9700.com/pub/technical/index.cfm
Alexreyes
Sep 30, 2015 11:30 PM
