Tire selection help-I need to upgrade to bigger tires
Ok here is the deal I have some nice 19x9 +26mm, 19x10 +22mm CX wheels on some BFG KDW2 in 235/35/19 and 265/30/19 lowered on Eibach Pro Kit.
I have some small gap on the back wheels that I would like to fill up, so why not upgrade to bigger tires. My tires have 10-15k miles on them but still have alot of tread. What to do?
Option 1:
-I can move the 265/30 to the front and should be ok with clearance, but some bigger 285/35/19 bfgoodrich tires for the rear-look funny maybe and cost $500 or so.
Option 2:
-Screw it I have used tires, just buy some used tires on cheap bay. Move the 265/30 BFG KDW2 to the front, and I found some used Michelin PS2 for $200 in sizes 295/30 right down the street from me.
Can I run 2 different types of tires without noticeing too much effects? Will the car be funny in the rain? Will the car look like it's at an OK height?
I know if anyone can help it would be this forum, so thanks for the respones ahead.
Option 1:
Option 2:
Performance Nissan
Performance Nissan
the 265/30 is a much smaller tire then desired for the 350Z...
just go to the standard 245/35/19 / 275/35/19 and you will be very happy...
the 265/30 is 1.5" too short for the rear of the 350Z (going by stock tire size diameter)...
Performance Nissan
Performance Nissan
yeah some tire models are taller then others... Potenza S0-3's are slightly taller then the same sizes from differnet makes...
Both of those tire sizes are considdered short for the Z... not much sidewall for a 19" wheel as well...
The KDW2's are available in 245/35/19 / 275/35/19... as well as alot of other tires...
