do they make a 19" drag radial
Old Jul 16, 2006 | 05:48 PM
350Z_LEE's Avatar
350Z_LEE
Default do they make a 19" drag radial
I have some bfg kdw2's in 19's, and I went to get some drag radials, only to find they don't make them in a 19. I checked for Nitto's too. Anyone know of a brand that does make them in a 19? I didnt think about that when i bought my rims :[
Old Jul 16, 2006 | 06:20 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Best thing to do is find some smaller rims and put drag radials on those... even some 17" stockers will do the trick (they will clear 13" big brake kits including OE Brembo's if you have etc)...
Old Jul 17, 2006 | 09:59 AM
Alberto's Avatar
Alberto
Cranky FI Owner
+1 Nobody makes 19" DR's, they make them up to some wide 18" sizes though....
Old Jul 17, 2006 | 03:41 PM
350Z_LEE's Avatar
350Z_LEE
Thanks, but dam! I didn't think about that when i got the rims. I have the BFG g force kdw's now, and i will be installing a 100 shot of nos in a couple weeks, and was wondering if i'll need new tires. Or if i switch to the regular KD's. hmm
Old Jul 17, 2006 | 03:55 PM
Jason@Performance
Performance Nissan
stickier rubber may not help you how you want...
you should look into somethign to adjust your rear camber to more of a 0 camber angle... get more rubber on the ground like a vette / mustang and loose some of the corner loving abilities... sounds like your more into drag racing then corner carving...
http://mynismo.com/categories/?id=2291
Old Jul 17, 2006 | 04:34 PM
350Z_LEE's Avatar
350Z_LEE
Thanks for the input guys.
Old Jul 17, 2006 | 06:31 PM
Alberto's Avatar
Alberto
Cranky FI Owner
www.iapdirect.com for the best camber/toe solution on the market-do not buy toe/traction rods, simply buy camber arms, and eccentric toe bolts to dial in more + camber for added traction. If you dial close to zero, say -.5 you will see a huge improvement in straight line grip.
Old Jul 17, 2006 | 06:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
here you go (save some money while you're at it!)
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1314
I'd suggest running around .5 degrees rear camber, 0 rear toe
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
