Got 18X9.5 and 18X8.5 wheels on order!! tires?'s..
Old Aug 4, 2006 | 09:06 AM
MarkRacerX's Avatar
MarkRacerX
Default Got 18X9.5 and 18X8.5 wheels on order!! tires?'s..
I don't like big sidewalls and I plan to autocross, would you guys suggest 30 or 40 series??
At 1st I was thinking 275/40/18 rear and 245/40/18 for fronts...
Ater seeing pics those tires seem really big, thinking about going 30 series or narrower tire if possible??...
Any input?? Pics? 30 vs 40 series? Pros / cons
Thanks!
Old Aug 4, 2006 | 09:47 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Thats the standard...
you could do 245/35/ 275/35 ... hat would give you a little less sidewall, less tire weight, better accleration as if you changed final drive gears...
Old Aug 4, 2006 | 09:49 AM
Zreign's Avatar
Zreign
35 series would be ideal. maybe try a 285/35/18 rear and 255/35/18 front
Brick-Z's Avatar
Brick-Z
For less sidewall, go with the 35. A 30 series may not work.
Old Aug 4, 2006 | 12:19 PM
Sponge's Avatar
Sponge
Jason,
As the overall diameter is less, would this make VDC unhappy?
Or is it the ratio front:back that is measured?
Old Aug 4, 2006 | 12:27 PM
Jason@Performance
Performance Nissan
as long as the tire diameters are relitive to eachother its fine...
example...
265/35/18 & 295/35/18
245/40/18 & 275/40/18
245/35/18 & 275/35/18
275/35/18 & 305/35/18
etc etc
245/40/18 & 275/35/18 MAY have VDC issues depending on the car model...
Old Aug 4, 2006 | 02:41 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
about to try it next week so I'll post the results. I don't have VDC, but i figure TCS should still not want to cooperate if there is an issue
Old Aug 4, 2006 | 02:52 PM
Jason@Performance
Performance Nissan
I think it looks funny with the rear wheel smaller....
There is a way to re-calibrate the TCS / VDC System...
I havent done it in a while...
but its something like...
turn the key into the ON position (not engine started...)
Roll the car backwards about 6 feet, roll the car forwards about 6 feet...
and that is suposed to re-calibrate the system...
Old Aug 4, 2006 | 02:56 PM
Z1 Performance
Former Sponsor
it may or may not....I've got nothing else to do but try though.
I've come to realize over the years there is no "standard' in tires - some look HUGE on the car height wise, some look huge width wise, but the only way to know how it will look and behave is to try
ablaine
Nov 29, 2016 10:13 AM
