03-05 Track Rays on non-Brembo?
Old Aug 11, 2006 | 11:21 AM
iceburns288's Avatar
iceburns288
Default 03-05 Track Rays on non-Brembo?
These should fit an 05 base Z, correct?
By the way, I've been searching for 1+hr, so if you say search...
Old Aug 11, 2006 | 11:29 AM
plumpzz's Avatar
plumpzz
They will. Your 17' wheels also fit the brembo brakes too. You'll need a wheel spacer if you want the 'flush' look aswell.
Old Aug 11, 2006 | 11:30 AM
masterj26's Avatar
masterj26
yes they will fit
Old Aug 11, 2006 | 11:31 AM
iceburns288
Well, the problem is, they won't. I bought some Track rims and they won't go on my hub!
My car came with aftermarket wheels on it. Can someone post a picture of their stock hub so I can see if anything's different about mine? It doesn't look like my car has spacers. BTW, I feel dumb.
Old Aug 11, 2006 | 11:36 AM
plumpzz's Avatar
plumpzz
It takes some muscling to do. Its hard to get it in, but once it goes in the hub, itll torque down to be perfect.
Do you have a hubcentric ring? Its a peice of plastic circle that makes sure all the wheels are aligned on the hub right.
Old Aug 11, 2006 | 12:10 PM
iceburns288
^Yes, there's a spacer around the actual wheel hub. The hub on my wheels is larger than the stock Nissan hub, obviously. The spacer's metal, though, and I've no idea how to get it off!
Old Aug 11, 2006 | 12:13 PM
iceburns288
One of these:
Around the hub.
EDIT: aha, that: http://www.miata.net/garage/hubcentric.html
Old Aug 11, 2006 | 01:18 PM
iceburns288
WTF AAAGGGGHHHH!!!! I got three off, but the front right wheel won't come off. The holes for the lug nuts are too small for my socket to fit into! Very weird because it fit fine into all the others with plenty of room. It won't even go into four of them, and my socket just got stuck in the fifth! wtf?
Old Aug 11, 2006 | 03:35 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
sounds like a wheel lock now...
yeah, you most likely have hub rings on your car...
take those off...
you probably already have the front bolts removed from the rotors already so that shouldnt be an issue...
Old Aug 11, 2006 | 03:48 PM
Take your time and work this through. The ring and hub are fused together. Use some penetrating fluid. Let it sit. Tap the ring with a chisel and hammer. Any progress?
Move to Plan B. Rent a nut-buster. A BIG nut-buster!
Old Aug 11, 2006 | 04:37 PM
imonlykidden's Avatar
imonlykidden
