what causes rear wheels to tip inward at top
Old Aug 26, 2006 | 05:49 PM
Gerry's Avatar
Gerry
Default what causes rear wheels to tip inward at top
Ive noticed that on the Z and even BMW's that the rear wheels tip inward at the top. Ive noticed this on my Z even more now that I went to a wider rear wheel (10.5")? Will the rear tires wear faster on the inside?
thanks,
Old Aug 26, 2006 | 05:55 PM
Nitrouz's Avatar
Nitrouz
Back to Z
it's called negative camber. Yes it will cause your tires to wear out quicker on the inside.
Old Aug 26, 2006 | 06:00 PM
andy2434's Avatar
andy2434
Yeah, when I mounted my 9.5/10.5 wheels, my camber went even more negative than it normally had. I had the SPC camber/toe bolt combo installed at the rear and am waiting on the new SPC front camber arms to be delivered. My car is a daily driver, so I didn't want my new tires wearing out any sooner than needed.
Old Aug 26, 2006 | 06:13 PM
stein's Avatar
stein
Some neg camber is good! When you corner hard the tire contact and angle will hold the road much better that if you had 0 camber. Stock specs on most sport(y) cars have some neg camber.
Old Aug 26, 2006 | 06:18 PM
Gerry's Avatar
Gerry
Thanks for the replies! I did a search for negative camber and it seems like the consenses is that you do not need to adjust camber for a wider rim and tire setup, but you would if you lower it.
Old Aug 26, 2006 | 08:12 PM
Chad68's Avatar
Chad68
How come the fronts don't use negative camber? Or do they?
Old Aug 26, 2006 | 08:16 PM
Correct. Changing wheels should not effect alignment.
Old Aug 26, 2006 | 08:18 PM
Yes. About -1 degree. Racers run -1 to -3 degrees of camber.
Old Aug 26, 2006 | 08:24 PM
jinsei888's Avatar
jinsei888
lol...it's negative camber, MANY high performance rear drive cars are setup up mildly negative from the factory for better left/right rear stabilitiy
Old Aug 27, 2006 | 04:35 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
changing wheels DOES change your alignment, as it alters how the tire contacts the road. As you alter the location of the wheel relative to the hub of the car, alignment will change
How much it changes it depends on your tire section width, and the offset/width of the wheels you install
Old Aug 27, 2006 | 07:25 AM
Gerry's Avatar
Gerry
I went with Tire Racks recommendation (they are usually conservative, I went with :18x9 +31mm offset in front and 18x10.5 +43mm offset in rear.
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
