LE37 with offset +12?? HELP needed
Old Aug 27, 2006 | 06:49 AM
JDMZ-33's Avatar
JDMZ-33
Default LE37 with offset +12?? HELP needed
Hi Guys,
I'm going to order my Volk racing LE37 with size front 19 x 9.5 offset +12 and rear 19 x 10.5 with offset +22. The problem is my Z its a track version, so not sure whether the front wheels with offset +12 will fit in without hitting the brembo breaks?
Anyone with LE37 running offset +12,Help please...
cheers,
Jerry
Old Aug 27, 2006 | 07:22 AM
Spec_Tacular's Avatar
Spec_Tacular
19x9.5 wit +12 will stick out of the front wheel wells. I have 19x9.5 +21 and they stick out just a touch but looks perfect no rubbing. That set-up will stick out by like a centimeter.
Old Aug 27, 2006 | 09:22 AM
JDMZ-33's Avatar
JDMZ-33
Thx,but i'm looking for the offset 12
cheers,
Jerry
Old Aug 27, 2006 | 09:42 AM
eyustfu's Avatar
eyustfu
the +12 should fit fine, its not the offset that clears the calipers but the spoke design. Since the LE's seem to clear the OEM brembos fine then the ones in a lower offset should do the same.
Old Aug 27, 2006 | 10:41 AM
JETPILOT's Avatar
JETPILOT
The pad thickness is what determines weather it will clear the brakes or not. 9.5 +12? Wow!!! I wouldn't go that route.
JET
Old Aug 27, 2006 | 11:42 AM
Curt941's Avatar
Curt941
Sharif from Forged Performance has the +12 LE37's on his Z.
Old Aug 27, 2006 | 01:11 PM
KLN's Avatar
KLN
I remember when the member "M77erlin" or something like that had LE37's in 19x9.5 +12 and 19x10.5 +22 on his G35 coupe with Brembo brakes. He used a 3mm spacer in front to clear the Brembos, but once he switched to a different BBK he did not need the spacer...
Old Aug 27, 2006 | 03:01 PM
JDMZ-33's Avatar
JDMZ-33
Thx for answering guys and yes, i PM Sharif about it and he got 6 pot AP racing in front.So offset +12 should fit in without problems
cheers,
Jerry
Old Aug 27, 2006 | 03:44 PM
synth19's Avatar
synth19
what size tires your running?
Old Aug 27, 2006 | 05:58 PM
JDMZ-33's Avatar
JDMZ-33
I plan to use 245/35 and 275/35
Old Aug 27, 2006 | 06:26 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You might need quite a bit of negative camber to make +12 work. I am 95% sure it should fit the brembos. Best of luck, +12 is not for everyone
Old Sep 1, 2006 | 12:54 PM
NISMOFO's Avatar
NISMOFO
Yeah, but those wheels stick out like a low rider in a Dr. Dre video on the front of his car. The stretched tires make it look not so bad. On a street car that is just crazy.
I have 9.5" LE37T's on the front with +22 and they are flush if not sticking out just a little with about 1" of drop.
I'm afraid to do a camber kit up front because I don't want to mash my fenders.
Old Sep 1, 2006 | 07:06 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it will clear your Brembo or most any other big brake kit, with ease
Old Sep 1, 2006 | 10:21 PM
Volk350Z's Avatar
Volk350Z
Master
I put 18x10.5 +22 on my car before with 285/30/18 and no problem for my track setup.. pretty much 18x10.5 +22 is the same as 18x9.5 +12 so is the same as 19x9.5 +12.. Also the +12 will clear over stock brembo & any other BBK..
Old Sep 1, 2006 | 10:28 PM
VN_350z's Avatar
VN_350z
Originally Posted by JDMZ-33
Hi Guys,
cheers,
Jerry
better to get offset +22. It'll line up with ethe fender evenly. +22 will clear BBK for sure. Same as +12.
Old Sep 2, 2006 | 09:10 AM
chewychew's Avatar
chewychew
Default 9.5 +12
obviously there would not be an issue with brake caliper clearance, since its a lower offset, you can fit +22 on that set up , ur totally fine, theres a black z with le37t that has 9.5 +12 up front, he says its " coveted" hahh , anywasy, i think its an EMOTION CAR.
Old Sep 2, 2006 | 09:13 AM
chewychew's Avatar
chewychew
ur gonna need lots of canber to make it look decent otherwise u cant slam it, mine is slammed on 9.5 +22 up front and when i put my cusco arms in, its gonna be flush, right now its fine. +12 is gonna be tough, u can def fit them, its gonna look like a monster truck, IMO Are you going for that flush drifter look? haha better run a strecthed tire then. here some pics of mine
its sitting on +22 all around, putting 5 mm spacers all around, just been lazy.
http://www.xanga.com/jchewy
Old Sep 2, 2006 | 09:21 AM
chewychew's Avatar
chewychew
heres the link to the gold wheels thread:
https://my350z.com/forum/showthread....189044&page=10
ask , vq.turbo.Dremz
Old Sep 2, 2006 | 09:33 AM
JDMZ-33's Avatar
JDMZ-33
Thx for answering,guys. I will post some pics soon
cheers,
Jerry
Old Sep 2, 2006 | 06:48 PM
TayTaythatsme04's Avatar
TayTaythatsme04
ask sharif, thats his car on the emotion team and the LEs running +12 up front, and I think he also has a BBK
but talk to him
T
