Tire Gurus....am I retarded?
Originally Posted by connman
In short, yes. The width/height ratio has nothing to do with the wheel diameter. You probably should have done your homework before blindly buying tires.
so what you are saying that 295 is not the width it's a combination of everything? so what tire would you suggest I get then?
Originally Posted by mrtomcat
not buying blindly. I needed a DR that's wider than 275, next is 295, that's the only available one.
.295 is the width, but that's not the problem here. Take a look at this - required reading for anyone buying tires.
http://www.justtires.com/services/ti...fications.html
Sounds like you're picking your tire sizes like your picking lotery numbers ! Lol
If the cryptic tire size equations don't stick, most manufacturer will give the tire overal diameter along with the tire spec. Aim for ~26.7 inches.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
