03-05 Touring wheels
Old Oct 30, 2006 | 06:55 PM
Jyoder7's Avatar
Jyoder7
Default 03-05 Touring wheels
Does anyone know if these wheels will clear the stock brembos? Thanks.
Old Oct 30, 2006 | 07:05 PM
Wheel offset can be found here: http://www.350zmotoring.com/modules....ex&name=Wheels.
Old Oct 30, 2006 | 07:13 PM
Jyoder7's Avatar
Jyoder7
Originally Posted by davidv
Correct me if i'm wrong but the rear wheels have a rear offset of -.33, which should mean the center of the wheel is further away from the vehicle. So these wheel should have even more clearance than the wheels available on the track model? I'm not sure i'm my thinking is correct but it seems that they should be able to clear the brembos.
Old Oct 31, 2006 | 03:43 AM
JokerDev's Avatar
JokerDev
18" touring on 04 will clear front brembos (I upgraded my brakes), so they should fit back also
Old Oct 31, 2006 | 06:38 PM
Jyoder7's Avatar
Jyoder7
Thanks for the help, if they clear the front they should have know problem clearing the back.
Old Nov 1, 2006 | 09:30 AM
Correct.
Old Nov 1, 2006 | 09:45 AM
arizzee's Avatar
arizzee
close but no cigar
'03 - '05 18" wheels (except Track model) are 18"x8" 30mm offset on all corners.
'03 - '05 Track wheels are 18x8" 30mm front and 18x8.5" 33mm rear.
All '03 - '05 wheels (including 17" wheels) will fit over factory Brembos.
Note: Not sure about the Grand Touring wheel offsets or sizes, but would like to know
Old Nov 24, 2006 | 05:57 AM
amolaver's Avatar
amolaver
arizzee can you forecast fitment for 17x9.5 +35 wheels all around? i'd really like to run the same wheels (and tires) front and rear if possible. i have the 13" stoptech kit. i currently am using 17" enthusiast (OEM) wheels with no problems, but they are HEAVY.
ahm
Obadabot
Jun 18, 2023 11:31 PM
