Luff M1 19's rubbing in front??
Old Nov 22, 2006 | 07:20 PM
nzpv03's Avatar
nzpv03
Default Luff M1 19's rubbing in front??
I just put Luff M1's on my 2004 z coupe, and it sounds like it may be rubbing when i turn the wheel to the right...I'm not quite sure...has anyone had this kind of problem? btw they are 19x8.5 in front and 19x10.5 in the rear...thanks guys
Old Nov 22, 2006 | 07:28 PM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
https://my350z.com/forum/forumdisplay.php?f=60
https://my350z.com/forum/maintenance-and-repair-53/
Old Nov 22, 2006 | 07:36 PM
nzpv03's Avatar
nzpv03
why take the time to find a link and copy/paste it if you can just type up an answer instead?
Old Nov 22, 2006 | 07:38 PM
zz350zz's Avatar
zz350zz
he's emphasizing the point to use the search function before you start a thread asking a question such as this.
Old Nov 22, 2006 | 07:48 PM
HighwaySpeed
Lightbulb
You will usually get the best answer to a question, in the proper forum.
Old Nov 22, 2006 | 07:52 PM
nzpv03's Avatar
nzpv03
i searched! and pm'd owners just share your knowledge with me please! I appreciate it!
Old Nov 22, 2006 | 07:53 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Thought this was a WOW forum. With all the flaming going on.
Wow that is cheesy isn't it.
Old Nov 22, 2006 | 07:57 PM
HighwaySpeed
Question
1] Are you the original owner?
2] Does the car have a stock suspension?
3] Has the car been "lowered"?
4] Has the front of the car/front suspension ever been damaged?
5] What size are the tires?
6] What is the wheel offset?
Old Nov 22, 2006 | 08:01 PM
nzpv03's Avatar
nzpv03
1. i just traded another member
2.the suspension is stock
3. it has not been lowered
4. I got into a little fender bender before...replaced front bumper
5. Thses are 19 inch luff M1 wheels
Front 245-40-19
Rear 285-35-19
6. i dont know the offset...=/
Old Nov 22, 2006 | 08:02 PM
nzpv03's Avatar
nzpv03
oh and thanks for helping me out!
Old Nov 22, 2006 | 08:03 PM
tresfifdeeZ's Avatar
tresfifdeeZ
why would u run a 40 profile in the front. thats pretty thick for a 19' rim
Old Nov 22, 2006 | 08:09 PM
HighwaySpeed
Question
Front 245-40-19
Rear 285-35-19
6. i don't know the offset...=/
Did the former owner have this problem?
Was this wheel/tire combo on the car at the time of the little fender bender? If so, did you have the problem before the incident?
The TireRack recommends a 225/40-19 size front tire on a 19 x 8.5 wheel and a 245/40-19 size rear tire on a 19 x 10 wheel.
michaeljr6's Avatar
michaeljr6
sweeet
Old Nov 22, 2006 | 08:12 PM
nzpv03's Avatar
nzpv03
Um no he didnt, and they were not on the car when i was in the fender bender! I didnt pick how thick the tires were...i just made a trade =/
Old Nov 22, 2006 | 08:43 PM
nzpv03's Avatar
nzpv03
ohh so what does it mean when mine are different?? btw the post above is reply to this also...thanks
Old Nov 22, 2006 | 09:04 PM
yoichi's Avatar
yoichi
i run 245/40 on my 19" TE37s, did fender roll though but can't even fit a figer in between the gap
Old Nov 23, 2006 | 01:30 AM
HighwaySpeed
Unhappy
Wrong size tire/wheel/wheel offset = rubbing
If I've ever had a tire/wheel question, I would always contact... http://www.tirerack.com/about/contact.jsp
Old Nov 23, 2006 | 08:49 AM
Agree. If the tires rub - they rub.
The question is where do they rub and what is a possible solution. With time the tire should show a rub mark. Or you can paint the tires with white sportsmans paint. If the rub is on the inside of the tire, a simple 5mm spacer may be the solution. If the rub is on the outside of the tire, then it might be time for some different size tires.
If one tire rubs and the other is OK, them the solution becomes more complicated.
Old Nov 23, 2006 | 10:43 AM
nzpv03's Avatar
nzpv03
are you dropped?
nzpv03's Avatar
nzpv03
i believe they rub on the inner fronts when i turn the wheel to the right!
