Winter Tire Size?
Old Nov 30, 2006 | 03:55 PM
06 350Z's Avatar
06 350Z
Default Winter Tire Size?
Sorry for this potentially stupid question......
What size of winter tire should we get?
Stock have front 225/45/18 rear 245/45/18. I am going with 17" steelies, and it works out to be front 225/50/17 and rear 225/55/17 so the overall diameter will be the same. But I called few tire shops and they said most of the time people use the same size all around. One shop suggested 225/50/17 all around and the other said 225/55/17 all around. What do you guys think? Will I have any problem with TCS or VDC if I have the same size all around? Any input is greatly appreciated, thanks in advance!
Old Nov 30, 2006 | 04:23 PM
For winter tires thin is in. A 17x7 wheels works well. The rear tires should be 10mm taller than the front.
Old Nov 30, 2006 | 04:58 PM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
https://my350z.com/forum/forumdisplay.php?f=60
http://www.tirerack.com/
http://www.tirerack.com/snow/WinterP...oModClar=Coupe
Old Dec 1, 2006 | 03:04 AM
FritzMan's Avatar
FritzMan
I'm running 215/65/16 Blizzaks on steel wheels all round.
Nice and narrow to cut through the snow and slush.
I've been running non stagger for 3 years now (summer, winter, Solo2) and there's zero issues, VDC works as usual.
Old Dec 1, 2006 | 04:17 PM
Barmats's Avatar
Barmats
The tire sizes recommended will be within .1" of the stock diameters, thereby retaining the stagger. There will be no negative effect on TCS and/or VDC. It will tolerate about an inch difference in diameter between front and rear. Use a tire size calculator like this one: http://www.miata.net/garage/tirecalc.html
Take a look at this post to see what I ended up with for winter wheels and tires: https://my350z.com/forum/wheels-and-tires/233668-pics-of-my-new-winter-wheels-and-tires.html
Old Dec 2, 2006 | 09:32 PM
Swiffer's Avatar
Swiffer
I called tirerack and got a set from them. I already went through a test fit, and they work just fine.
Front:
17x7 Sport Edition E2
225/50/17 Bridgestone Blizzak LM-22
Rear:
235/50/17 Bridgestone Blizzak LM-22
Old Dec 2, 2006 | 09:33 PM
Swiffer's Avatar
Swiffer
Your car reminds me of a war vehicle
Old Dec 3, 2006 | 05:24 AM
06 350Z's Avatar
06 350Z
Thanks everyone for the great advice!!!
Old Dec 3, 2006 | 01:08 PM
06 350Z's Avatar
06 350Z
I just got my winter tires on and the car have a small vibration if I brake slightly harder. ABS didn't kick in. Is this normal for car equips with winter tires?
Old Dec 3, 2006 | 06:26 PM
jhau's Avatar
jhau
Default tires size
i run 215 60 16 front and 225 60 16 rears I think. Just put them on today
Old Dec 5, 2006 | 06:07 PM
Barmats's Avatar
Barmats
Absolutely not normal... Did you mount the wheels in accordance with the correct torque specs (about 85 lb-ft per lug nut) and bolt-tightening pattern? You should always recheck your wheel torque a couple of weeks after initial mounting, but it sounds like there's something wrong right off the bat. It could be a loose wheel or two or something else that's not quite right. You should check it out and get if fixed asap!
Old Dec 7, 2006 | 06:33 PM
Zmazing03's Avatar
Zmazing03
I just put my Blizzaks on today. 225/50/17 all around.
lapham3
Oct 7, 2022 03:15 PM
