motegi touge wheels?
I'm thinking of running motegi touge wheels in 18". They offer 18x7.5 18x9 and 18x10. I guess I should do 18x7.5 and 18x10 with a 245/40 and 285/35? What offset do I need? If i can do 18x9 and 18x10 what tires and offset do I need? I also plan on lowering the car in the near future, should I go with a little smaller tire? Thanks for any help in advance
Ryan
Ryan
2176-896525 18x9 +25 6 5x4.5 26 lbs.
2176-896512 18x9 +12 5 1/2 5x4.5 26 lbs.
2176-87580 18x7.5 +45 5 7/8 5x100 25 lbs.
2176-87565 18x7.5 +45 5 7/8 5x4.5 25 lbs.
2176-87549 18x7.5 +45 5 7/8 4x100 25 lbs.
2176-87548 18x7.5 +45 5 7/8 4x4.5 25 lbs.
2176-8165 18x10 +30 6 5/8 5x4.5 27.5 lbs.
2176-8148 18x10 +30 6 5/8 4x4.5 27.5 lbs.
Ryan
Ryan
Originally Posted by syk69
hey i got these same wheels on my car with toyo proxes t1r's. in the front i went with 18x9 +25 and the rear with 18x10 +30, for the tires i got 245/40/18 up front and 285/35/18 for the back. fits with no problems, and i'm loving it! by the way i'm not lowered and got my alignment done with no problems. i think they are gorgeous looking wheels. good luck!
- j
Got the 18X9F 25mm offset Falcon 452's 245's and 18X10R 30mm offset Falcon 451's 285's. Im lowered about .75in and the only issues with rubbing I had was with body roll before suspention mods (Cusco A-arms, Tein Flex coil over, Hotchkis adjustable sways, Full GT spec Chassis bracing). It would only rub during real heavy turns at high speeds (35mph offramp loop taken at 65mph). Alignment is -1 front -1.8 rear. AVIC D1 acceleramoter measured over 1.2 G's.
Since suspention mods 0 rubbing issues.
Id rather spend that extra money on making more power. If you have enough power the extra 5lb wont meen squat. So if your pushing 650hp, and free up 20lbs of rotating mass it will feal like 656ish HP.
Ooooohhh Aahhhhhh.
If Im that hard up for performance I need to have big name sponsors on the car.
Ooooohhh Aahhhhhh.
im running motegi touge rims
went with 18x9 with 245/40/18 front +25mm offset
and 18x10 with 275/40/18 rear +30mm offset
i have an eibach pro kit with 1.2" drop aswell
no rubbing at all.
no rubbing at all.
