tire size and vdc problem?
Old Dec 24, 2006 | 05:19 AM
Hella's Avatar
Hella
Default tire size and vdc problem?
I have 03 track wheels. I want to move my 245/45's that are on the rear now to the front wheels, and then put 265/40's on the back. Does anyone see a problem with doing this? VDC problems?
Thx in advance.
Old Dec 24, 2006 | 07:21 AM
DavesZ#3's Avatar
DavesZ#3
You will definitely have problems with that setup. The 245/45/18" tire is 26.7" in diameter. The 265/40/18" is only 26.3" in diameter. The rears can't be shorter than the fronts, they need to be around 0.5" taller.
You would need to go with a 265/45 in the rear. If you stick with those sizes, then you'll also have a problem with the speedometer being inaccurate.
Typically when people up-size their tires, they use a lower profile to keep the overall diameters the same as OEM. For example, the usual step up from the stock 225/45 & 245/45 is to go to a 245/40 & 275/40.
You can check out size combinations with this handy little tool:
http://www.miata.net/garage/tirecalc.html
Old Dec 24, 2006 | 10:12 AM
Hella's Avatar
Hella
thanks. that is exactly what i was wondering.
Isnt a 275 a bit big to run on a track wheel? I thought 265 was as big as you can go.
Old Dec 24, 2006 | 10:18 AM
You can help yourself with similar questions with this calculator: http://www.dakota-truck.net/TIRECALC/tirecalc.html.
Old Dec 24, 2006 | 10:52 AM
PDX_Racer's Avatar
PDX_Racer
I've been running 275s on the rear 8.5s for over a year. No wear problems, the Z handles great!
They actually don't look as "pooched" as some people think that they would, and from the rear the car looks like a steam roller!
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
kyin
Oct 15, 2015 05:54 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
