17x9...what offset
Old Dec 25, 2006 | 06:11 AM
willyd6869's Avatar
willyd6869
Default 17x9...what offset
will a 17x9 wheel with 0 offset running a 245/40/17 fit on a z?
Old Dec 25, 2006 | 07:50 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yes actually it will work
how it will work (handling wise) is a completely different matter v- if you are looking to drift, could be a great setup. If you are looking for out and out grip, this won't get you there
Old Dec 25, 2006 | 08:24 AM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Dec 25, 2006 | 08:52 AM
z-u-later's Avatar
z-u-later
When using the offset calculator and you have spacers, do you just add the spacer size to the offset? For example, if I have a 30mm offset in front, do I add 20mm if I have a 20mm spacer in front? So, my offset then will actually be 50mm? I have an '06 with 18x8 rims and 20mm spacers in front.
Old Dec 25, 2006 | 09:01 AM
willyd6869's Avatar
willyd6869
these will be my drift wheels...Im looking at cheap wheels...they offer the wheels in 0mm,24mm,and 45mm...from the responses It seems 24 will be the way to go
Old Dec 25, 2006 | 07:46 PM
No. Well kind of:
-30mm offset + 10mm spacer = -20mm offset.
Old Dec 25, 2006 | 08:55 PM
Auto RnD's Avatar
Auto RnD
245/40/17 is an extremely short tire for the Z. Maybe it will help you with drift, maybe not. I guess it all comes down to what your average speed is in drifting. If this is for low speed drift then i think it can work to your benefit, if high speed i think you might end up between gears etc....
Old Dec 26, 2006 | 04:57 AM
Z1 Performance
Former Sponsor
What exact wheel are you looking for again?
Fn01RC is a good choice - 17x9 +15 all around
If you are factoring spacers in, spacers bring the wheel further out. A wheel that is a +20 offset, with a 10mm spacer, now has an effective offset of +10mm (sits 10mm further out towards the fender edge of the car). However, spacers do not affect pad height (the actual mounting surface of the wheel to the car), so make sure the wheels you get have a pad that can clear your brakes (a low offset is not a guarantee they will clear, varies from wheel to wheel)
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
