35th Anniversary/ 2006 Wheel Specs and Tire Upgrades?
Old Dec 25, 2006 | 11:53 AM
9kFever's Avatar
9kFever
Default 35th Anniversary/ 2006 Wheel Specs and Tire Upgrades?
Ok, I have searched and searched and searched. I found one thread talking about 18x8 (all around) wheels found on the 2005 touring. For the 35th Anniversary and 2006 Z's what is the specs? F-8 R-8.5? What is the widest I can run in the rear? I am trying to eliminate some of the understeer (I miss my s2000 ).
Old Dec 25, 2006 | 01:38 PM
PDX_Racer's Avatar
PDX_Racer
To eliminate understeer, you need to have the same size tires front and back. Part of Nissan's engineering understeer into the car was by using narrower tires in the front.
Personally, I'd suggest living with the understeer on the street and save the understeer for the track or autocross course.
Old Dec 25, 2006 | 01:47 PM
clark_carty's Avatar
clark_carty
Fronts are 18x8 and rears are 18x8.5.
Old Dec 25, 2006 | 02:37 PM
lowrider's Avatar
lowrider
Search, and you would have found this:
https://my350z.com/forum/wheels-and-tires/237205-275-40-18-on-stock-06-rims.html
Lou
Old Dec 25, 2006 | 03:25 PM
Frosty1's Avatar
Frosty1
Buy sways it should eliminate some understeer.
Old Dec 25, 2006 | 06:23 PM
9kFever's Avatar
9kFever
I have no idea what you meant by saying save the understeer for the track or autocross. Usually you widen the rear tires an run a skinnier front tire to make less understeer.
And no I cant just live with it on the street. After driving the s2000 for two years the handling on the Z is pathetic at best.
Old Dec 25, 2006 | 06:35 PM
9kFever's Avatar
9kFever
Ok, I looked at the other thread. If I run the 275 rear what should I run up front? I cant seem to find matching sets on tirerack.com
Old Dec 25, 2006 | 07:32 PM
PDX_Racer's Avatar
PDX_Racer
245s on the front.
Narrower tires = less grip = that end slides more.
Sorry, I started to write one thing and ended up with another. It should have been "save the neutral handling for the track or autocross."
Old Dec 25, 2006 | 08:49 PM
9kFever's Avatar
9kFever
245s on the front.
now im even more confused. You said to run the same size front and rear to eliminate understeer. now your saying run 245 front 275 rear?
Old Dec 25, 2006 | 08:56 PM
PDX_Racer's Avatar
PDX_Racer
On the street, 245/40R18 F, 275/40R18 R.
For autocross or track, 275/35R18, or better yet find someone willing to take the time (!) to mount 285/30R18s.
Old Dec 26, 2006 | 04:58 PM
Sensi09's Avatar
Sensi09
Works Concepts
Less stagger between front and back will result in less understeer. So something like 275/285, or 265 around would be good.
However, running those sizes will likely result in VDC issues.
Old Dec 26, 2006 | 04:59 PM
Sensi09's Avatar
Sensi09
Works Concepts
That would result in more understeer.
Old Dec 26, 2006 | 05:13 PM
9kFever's Avatar
9kFever
whats vdc...lol...never use that **** anyways...
Old Dec 26, 2006 | 08:32 PM
PDX_Racer's Avatar
PDX_Racer
I leave VDC on when I'm driving on the street.
It's off when I'm on course.
It's saved my butt a few times late in autumn when there's been wet leaves on the street, but I notice that I almost respond quicker than the computer. I guess that's what happens when you spend a lot of time working on car control on an autocross course.
Old Dec 29, 2006 | 03:10 PM
Got Me WORKIN's Avatar
Got Me WORKIN
Nah he needs to keep the cupholder full with a bottle of alcohol and it wont give as much keeping the body stiff, or he can just put the rear tires on the front and the front on the rear, it would look really cool.
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
