thoughts on wheel spacers...
Old Dec 25, 2006 | 07:46 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
Default your opinion on wheel spacers..
as the title says i need ur opinion guys..
i have stock 06 rims so should i put
15mm front / 20mm rear
20mm front / 25mm rear
thanks
Old Dec 25, 2006 | 08:15 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
bumps
Old Dec 25, 2006 | 08:19 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Why are you putting spacers on your car?
Old Dec 25, 2006 | 08:26 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
it look better.. and pluse not planning to get rims anytime soon
Old Dec 25, 2006 | 08:42 PM
JDMFairladyZ33
Well I am assuming you are trying to push the wheels out more to create a more negative offset look. The amount of spacing is really up to you how close to the fender you want your wheels to stick. Just remember the wider of a spacer you go with the more stress you are putting on your wheel studs because the weight bearing contact point is distributed further from the base of the stud.
Old Dec 25, 2006 | 08:55 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
i dont think 15mm will make a big difference
Old Dec 25, 2006 | 09:04 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
anyone else have input on this
Old Dec 26, 2006 | 07:37 PM
sluggoZ's Avatar
sluggoZ
Maybe if you post in the wheels section...you'll get more responses.
Old Dec 26, 2006 | 11:00 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
Default thoughts on wheel spacers...
click here plz..
https://my350z.com/forum/showthread.php?t=238965
Thanks..
Old Dec 26, 2006 | 11:01 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
ok click here plz..
https://my350z.com/forum/showthread....97#post3129397
Old Dec 27, 2006 | 04:36 AM
z-u-later's Avatar
z-u-later
I have H&R Trak spacers on my '06 Z -- 20mm front & 25mm rear. Here are a couple of pictures with my stock rims & tires:
There's nothing wrong with having spacers . . . I have taken it to the track & autocross, and it handles well with the spacers. The rims/tires are flushed on the fenders & gives it a more aggressive stance. My Z is lowered also if that makes a difference. I ordered the H&R Trak spacers from Performance Nissan. It's made from Germany and are used by almost all European sports cars (BMWs, Porsches, etc.) to give them that same look on my Z.
Obadabot
Jun 18, 2023 11:31 PM
